does this sound wrong to you?
发表于 2021-8-31 23:57:55 | 显示全部楼层 |阅读模式
i went onto millers site to check out the tig calculator so i could see what would be required to weld 1/4 in steel. according to miller ,mild steel requires 225- 300 amps to butt weld, where as to weld 1/4 in aluminum it only requires 190 to 220. i thought aluminum required higher amperage?Millermatic 211weldpack 3200 squirtgunsquare wave 200victory journeyman kitHypertherm 30xptoo much other crap to listtinkerer extraordinaire
Reply:i just checked the one i have, you must have done 3/16" aluminumfor 1/4" buttweld on aluminum it says:3/16" tungsten1/8" or 3/16" filler 260-300 amps25cfh argon
Reply:I think that would be in one pass.  DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:i just checked it again 3 times. i keep getting the same resultshttp://www.millerwelds.com/education...calculator.phphttp://www.millerwelds.com/education...calculator.phpMillermatic 211weldpack 3200 squirtgunsquare wave 200victory journeyman kitHypertherm 30xptoo much other crap to listtinkerer extraordinaire
Reply:Originally Posted by David RI think that would be in one pass.  David
Reply:i have the hard copy, the website is messed up apparently.and yes, its for one pass.
GMT+8, 2025-12-24 05:02 , Processed in 0.099187 second(s), 18 queries .
