Acetylene cylinder pressure vs temperature
发表于 2021-8-31 23:57:50 | 显示全部楼层 |阅读模式
FYI, here is a chart for the settled pressure for Acetylene. Settled pressure is the temp of a cylinder in a room for 12 hours, i.e if your cylinder spent the night outside, be aware of the fluxuation in reading your gauge.  NOTE: A full cylinder will read 250psi at 70 degrees. ps: I owned and operated an acetylene plant for 25 years...welders would bitch about empties in the winter, but never complained in the summer...go figureCut and paste this chart for your reference...no copyright...a freebie...just wanna educate everyone so we are all on the same sheet of music.Hope this helps...Respectfully submitting, Dan MAXIMUM ACETYLENE CYLINDER SETTLED PRESSURE - PsigTEMP   PRESSURE  TEMP    PRESSURE  TEMP    PRESSURE  TEMP   PRESSURE                 30,             138----------50,190-------70,250-------90,31531,139-----------51,193-------71,253--------91,31932,141-----------52,196-------72,256-------92,32333,144-----------53,199-------73,259-------93,32634,146-----------54,202-------74,262-------94,32935,149----------55,205-------75,265-------95,33336,152----------56,208-------76,269-------96,33637,155-----------57,211-------77,272-------97,34038,157-----------58,214-------78,275--------98,34439,160-----------59,217-------79,278-------99,34740,162-----------60,220-------80,282-------100,35141,165-----------61,223-------81,285-------101,35542,168-----------62,225-------82,288-------102,35843,171-----------63,228-------83,292-------103,36244,174-----------64,231-------84,295-------104,36645,176-----------65,234-------85,298-------105,37046,179-----------66,237-------86,302-------106,37447,182-----------67,240-------87,305-------107,37848,185----------68,243-------88,308-------108,38249,188---------69,247-------89,312-------109,386
Reply:Interesting first post Dan. Thanks for the info.Gas safety is one of my pet peeves.  I wish more folks would share and understand how this stuff works.
GMT+8, 2025-12-24 05:04 , Processed in 0.092207 second(s), 18 queries .
