fan motor horsepower
发表于 2021-8-31 23:57:27 | 显示全部楼层 |阅读模式
About how many hp  and CFM are the cooling fan motors in buzz box welders?  I am trying to replace the fan blade and the blades are sized by hp and CFM's of the motor.Also, an interesting site that tells a person how to determine whether a fan blade rotates CW or CCWhttp://www.fasco.com/pdf3/page44-45.pdf
Reply:These are small units - less that 1/8th HP open frame motors and small 4 or 5 blade axial fans.Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
GMT+8, 2025-12-24 05:35 , Processed in 0.090198 second(s), 18 queries .
