.023 hardwire
发表于 2021-8-31 23:57:27 | 显示全部楼层 |阅读模式
I went to one of the school systems other shops today which use to house the county' s welding program, but now is a building construction class.  Anyway, I was scavenging for leftover welding class stuff ( which was a goldmine I might add) and I ran across a 11 lb roll of .023 hardwire that was still sealed.  I was wondering if they might make a contact tip and drive rolls for my Lincoln 140c.  I have run .030  and .025 but In my inexperience have not run across .023.
Reply:.023, .024, and .025 are basically different names for the same thing. Use .025 tips and you'll be fine.The 140C will run that wire nicely with 75/25. Just make sure to use the correct drive rolls.JohnA few weldersA lot of hammersA whole lot of C-clamps
Reply:Originally Posted by Silicon-based.023, .024, and .025 are basically different names for the same thing. Use .025 tips and you'll be fine.The 140C will run that wire nicely with 75/25. Just make sure to use the correct drive rolls.John
Reply:Not sure about your machine, but on my weldpak 100, I have to turn the drive roller around to accommodate the smaller .025, .023 wire.
GMT+8, 2025-12-24 05:33 , Processed in 0.109771 second(s), 18 queries .
