c25 tank
发表于 2021-8-31 23:57:24 | 显示全部楼层 |阅读模式
How heavy should a full 130cuft c25 tank read full? thanks
Reply:I think you'd be better off measuring pressure.  It should be 2015 or 2200 PSI depending of the cylinder and/or outside temp and how much they actually filled.Millermatic Passport PlusMillermatic 200Millermatic 350P with PythonXMT 304 /w S-64 feeder and 12RCDynasty 300 DXVictor O/APremier Power Welder for my trail junk.
Reply:My reg. is brokew right now, so that wont work, but my tank feels light. It is only weighing 60 pounds.
Reply:There might be a pound or two difference in full and empty.  Regulator High Pressure gauge to tell how much you have in the cylinder.   JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:Would also depend on whether you have steel or aluminum cylinder- and how thick the steel is.  Get yourself a working gauge.Lincoln AC225 & MigPak 140, Lincoln Magnum SpoolGun, Miller Spectrum 375-X Plasma, Syncrowave 200 TIG, Millermatic 252 MIG, Miller Digital Elite, General 7x12" horiz/vert bandsaw, 3' box/pan brake, 20 ton press, milling machine, 12x28 lathe, etc.
Reply:Is your tank aluminum? My steel 80 cu ft has a tare weight of something like 60lbs empty. -Dan
Reply:i got a new tank and a new high guage. the tank was empty. Thanks. How far should i open the valve on the tank thanks.
GMT+8, 2025-12-24 05:33 , Processed in 0.094956 second(s), 18 queries .
