Al propane manifold crack
发表于 2021-8-31 23:57:22 | 显示全部楼层 |阅读模式
Manifold off a propane transport. Mechanic brought this in about 6 months ago and I welded cracked area (area in circle). Owner showed up with it again cracked on opposite side of repair. Told me that one of the supports was missing, another was loose. No wander it keeps breaking!Picsmanifoldprevious repairbubbles in cracked areacut out cracked areaweldedcloser look at weldtig, 4043 Attached Images
Reply:last pic Attached Images
Reply:Looks really good. I'd like to do some aluminum tig welding. Ive only tried it once and it was about a 4 inch t-weld and it turned out surprisingly good for a first try.My vintage equipment 1957 Lincoln sa 2001980's Lincoln 225 AC1952 F-2 ford truck1957 F-250 ford truck
Reply:Can anybody else see the photos? I can see that the code is there, but nothing shows up.
Reply:I don't see them either....
GMT+8, 2025-12-24 05:19 , Processed in 0.070405 second(s), 18 queries .
