A couple of Coffee tables
发表于 2021-8-31 23:57:21 | 显示全部楼层 |阅读模式
A couple of Coffee tables that are proving popular. Attached ImagesA good guess is better than a bad measurement
Reply:Ok that didnt work... Attached ImagesA good guess is better than a bad measurement
Reply:The "C" types are for going over an arm of a sofa for your ciggies or drinks, you can also eat off them.They are 12mm solid, powder coated "Jasper" with "Latte" painted 6mm toughened opti white glass (A a low fe glass that is very clear and no green tinge)The spider is a Octogon 10mm toughened glass, 30mm bevel, painted black , 12mm and 10mm solid mild steel, powder coated black done with a 415V PT 185 with 100 %  ArA good guess is better than a bad measurement
Reply:Nice work on all of them.  I like that octogon table, good finish.How are you attaching the glass tops?  Doing the frames, then screwing them together from the underside?
Reply:No it just sits there, so people can remove and clean them.The big one has 8 rubber self adhesive blobs  and it doesn't move at all , the few I did before that I silicone on 4 blocks so it couldn't slide off but I found it unneeded.A good guess is better than a bad measurement
Reply:The C types are located by the frameA good guess is better than a bad measurement
Reply:that's awesome! While its not my desgin style, ive been building furniture for 5 years now and will go full time this year having replaced my full time jobs income. I wish you the best ...  designing and building is soo much fun.
Reply:nice work
Reply:Originally Posted by BrettNo it just sits there, so people can remove and clean them.The big one has 8 rubber self adhesive blobs  and it doesn't move at all , the few I did before that I silicone on 4 blocks so it couldn't slide off but I found it unneeded. ... The C types are located by the frame
GMT+8, 2025-12-24 05:21 , Processed in 0.330357 second(s), 18 queries .
