trailer plans
发表于 2021-8-31 23:57:18 | 显示全部楼层 |阅读模式
i bought 3 trailer plans from northern toolsthere dot plans with step by step proceduresbill of materials engineer and dot approved blue printsi got 18' x 6'8" car trailer 16' x78" landscape trailerand car dolly plans they have a lot more i had the car trailerplans laminated heres some pics Attached Images
Reply:there 24"x36"  and realy good around $30.00 Attached Images
Reply:other plans Attached Images
Reply:Ed-They are nice plans! I have one set of plans for a utility tailer that look like the same format as yours..  I'm intrested in the car dolly plans, what did they set you back?JasonMiller 252Miller 250Miller Syncrowave 250Esab Plasma Powercut 1250HF Basic oxy/act torches
Reply:car dolly was $29.99 they 24 trailer plans
Reply:Nice plans! Its a shame I can't figure out a way to copy these so I can read them.
Reply:I've looked at the Northern plans in their catalogue and thought hard about getting either the flat deck equipment trailer or one of the hyd dump trailers. Thanks for posting the picts. Looks like they are well worth the money. I expected just a cheap set with a cut list and a few notes on one page. These look like you get something for your money!Thanks for the post, Now if you could only scan them into autocad for me...... Just kidding.Edit:BTW Good thinking on laminating the plans! We used to copy all our site work drawings onto mylar at the copy store so that mud, rain, snow etc wouldn't ruin the drawings we were using on site. Made changes on the mylar with sharpies if required. Never thought about having them laminated instead. I'll have to look at how much it costs to laminate a 24x36 sheet vs copying them on to mylar. ThanksLast edited by DSW; 02-03-2009 at 04:25 PM.
Reply:Ed,  those plans look pretty straight forward and easy to read.  very niceLincoln 255XT Power Mig        Lincoln Precision Tig 225Hypertherm Powermax 30
Reply:Originally Posted by DSWI've looked at the Northern plans in their catalogue and thought hard about getting either the flat deck equipment trailer or one of the hyd dump trailers. Thanks for posting the picts. Looks like they are well worth the money. I expected just a cheap set with a cut list and a few notes on one page. These look like you get something for your money!Thanks for the post, Now if you could only scan them into autocad for me...... Just kidding.Edit:BTW Good thinking on laminating the plans! We used to copy all our site work drawings onto mylar at the copy store so that mud, rain, snow etc wouldn't ruin the drawings we were using on site. Made changes on the mylar with sharpies if required. Never thought about having them laminated instead. I'll have to look at how much it costs to laminate a 24x36 sheet vs copying them on to mylar. Thanks
Reply:the plans a great and what i like is they give you the amount of steel you need to orderthen all you do is cut and weld i thought they would be cheep to but a northern tool store open down the steetand was able to see themoffice depot laminated them it was $50.00for 4, 24 x 36 sheet with 4 brass rings on eachone in each corner yes thats more than i paidfor the plans but they will last and i thoughtthey would look good on the wall in the shopLast edited by ed mac; 02-04-2009 at 09:34 AM.
Reply:what do you think the build time would be on the car trailer?  and a ball park figure on the material? i really can't see how much material there is from the pics.....
Reply:Originally Posted by farmersammThere's a couple of guys around here with the bumper pull dump trailers.  I think the most expensive part of the trailer is the hydraulic system because it's self containedI always figured if a guy had a tractor with hydraulic remotes, he could just build the trailer with the required cylinder, and use the tractor hydraulics to dump it.  It would probably only work in my situation where everything on a dump body would be coming onto my place instead of going off somewhere else.
Reply:I almost purchased these plans from Northern Tool.  After seeing this post I went straight to Master Plans and purchased them direct.  Maybe it is just me but I would rather go straight to the source in this case the little guy and eleminate the giant mega store.  https://trailerplans.com/index.php?o...tpage&Itemid=1Just my 2 cents.
Reply:that's some decent money to be made there.. good job..if you're not livin on the edge, you're takin up too much room..
GMT+8, 2025-12-24 06:49 , Processed in 0.100115 second(s), 18 queries .
