Pre Bent Tubing
发表于 2021-8-31 23:57:18 | 显示全部楼层 |阅读模式
Can anyone recommend a source for pre bent, weldable tubing corners, for a guy without a bender?  Also looking for sleeves, or nipples to make them stronger where they meet the pieces?  Sorry for the lack of terminology.Looking to ad some more protection to the fender of this rig.  They used to be an option on these rigs, but the manufacture is no longer in business.  It bolts on to the over head part, and swivels on the post when you loosen the set bolt.It is not load bearing, FYI. Attached ImagesLast edited by brendonv; 02-29-2012 at 03:36 PM.
Reply:http://www.sharpeproducts.com/archit..._fittings.htmlAlthough those are for Pipe, they'll probably work for youEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Also look at King Metals. They sell stuff of hand rails including prebends and joining clips.Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:Also try http://www.wagnercompanies.com/Domai...ges/search.htm
Reply:Thanks
GMT+8, 2025-12-24 05:20 , Processed in 0.128148 second(s), 18 queries .
