Pipe casing, 6g ?
发表于 2021-8-31 23:57:17 | 显示全部楼层 |阅读模式
Hello, Gonna be honest I have no clue what I am talking about when it comes to pipe casing. I was just wondering if you can practice 6g with pipe casing? The supplier has a lot laying around so I figured I'd ask. Thanks for your time !
Reply:Cmon Anyone? Can pick it up now that's why I'm rushing lol
Reply:6" sch. 80 pipe with a .432" wall thickness is used. How does the casing compare? If you are actually practicing for a test, you will want the right pipe.Leo
Reply:On the other hand, if you just want some scrap to practice running beads on, go for it.
Reply:you can use it..... you can 5p root it and 7018 it out, or tig root, 7018 it out...... if you jsut praticing who cares what it is
Reply:Originally Posted by astaindsoul5446you can use it..... you can 5p root it and 7018 it out, or tig root, 7018 it out...... if you jsut praticing who cares what it is
GMT+8, 2025-12-24 05:35 , Processed in 0.098466 second(s), 18 queries .
