4G 7018 cert.
发表于 2021-8-31 23:57:11 | 显示全部楼层 |阅读模式
well like the title says. i whiped out my 4G cert. plates today cut them up on the band saw st school and sent them down to PSI to get them bent up.  here is a pic for you all to check out. i took it on my cell phone so its not the best quality. sry. i am going to be going for my hard wire 035 later on. and then this fall i will get my cert in TIG. abd then the fun begins....4G 7018 cert.http://i112.photobucket.com/albums/n...4gcert7018.jpg
Reply:not bad at all, your covers look high to me, but it might just be the angle
Reply:i think its the angle and my crapy cell phone that i took the pic with. my covers were acutuly very low. I got the results back this afternoon at it PASSES so i was prety stoked. but ya.i am going to go for my hard wire next....
Reply:Congradulations on passing the cert!  I thought the caps looked high also, but figured it was the angle the pict was taken posibly. Keep at it and good luck on the next one.
Reply:thank you for you coments everyone...
GMT+8, 2025-12-24 05:20 , Processed in 0.124354 second(s), 18 queries .
