2 carts
发表于 2021-8-31 23:57:09 | 显示全部楼层 |阅读模式
hey! i'm new to this forum but have been looking around here for a while, just thought i would post a couple of the carts I recently built. Attached Images
Reply:a few more pics. now go ahead and tear them apart!!! Attached Images
Reply:fully functional,cool design, nice big tires for easy mobility inside or out! nice job        Bob
Reply:Both carts are very well thought out and look great and I know pneumatic tires roll great on stone or dirt, but my problem with them is getting a flat. That first cart looks a bit top heavy and could be a problem if a tire went down. I prefer hard rubber tires. Just my two cents. Great job.
Reply:Yeah....good stout carts with big knobby tires!I'm always moving around on rough ground so those big wheels catch my eye. And I like a cart that makes you look up the load range of the casters before you buy them...and that's before you add the weight of the welder and tools.AlA man is judged by what's between his legs...always ride a good horseMiller DialArc HFLincoln Classic 300DThermal Arc 181iPowermax 45Scotchman Ironworker(2) BridgeportsOkomota Surface GrinderAutoCAD 2010
Reply:Nice carts ... I like the offraod tires - those definitely are a must.
Reply:Thanks for all of the positive replies.  I'm not quite done with them, after I loaded them down I think i'm going to add a third wheel to the back of the first cart to help out with the weight of the tanks.  These tires are rated at 300 lbs apeice and since there harbor freight tires I want to be very carefull.  now I'm getting ready for my next two projects, i'm going to build a set of trailer ramps and then a bow fishing deck because spring is right around the corner!!!  I will definatly be posting pics as I go along.
Reply:Originally Posted by trapperjohnBoth carts are very well thought out and look great and I know pneumatic tires roll great on stone or dirt, but my problem with them is getting a flat. That first cart looks a bit top heavy and could be a problem if a tire went down. I prefer hard rubber tires. Just my two cents. Great job.
Reply:I like your Idea of foam filled tires however i hate to raise it up another 3 inches.  I was wondering what anybody's thoughts are on products such as tire slime or simillar to help prevent flats?
Reply:tire slime is good!millermatic 200 millermatic 150miller bluestar 2Epurox / oxweld O/A
Reply:Those carts look great, the pneumatic casters are a perfect idea - good job
Reply:It's amazing how much work goes into a simple cart, eh? Don't wait for a flat, slime those tires.  Nice work.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:thanks again, I've used tire slim before on 4 wheelers but i was just going to make sure first that you can use slim on TUBE tires.  thanks in advance.
GMT+8, 2025-12-24 05:20 , Processed in 0.099563 second(s), 18 queries .
