What do you use for stake holes?
发表于 2021-8-31 23:57:08 | 显示全部楼层 |阅读模式
I want to add removable sides to my flat deck trailer, what is a good method of making the stake hole for a 2x4?I figure there must be something that can be welded on to the side, I also going to weld on something for some straps.
Reply:I buy these from my local steel supplier  http://www.redtrailers.com/ShowItem.asp?id=C-J72 Can't make a hole for that price.  Travis
Reply:2X4X3/16 tube steel fits a 2x4 real nice for stake pocketsVisions SteelWasilla Alaskahttp://www.facebook.com/album.php?ai...5&l=c32ed1320fwelderstourchessawsgrinders
Reply:Originally Posted by IRONARTIST2X4X3/16 tube steel fits a 2x4 real nice for stake pockets
Reply:Found these in the Princess Auto website, not a bad price.$3.99 eaStraight pocketPocket opening measures 3" x 1-1/2"Last edited by partsman; 02-23-2010 at 10:01 PM.
Reply:I was just thinking today, does anyone make aluminum stakes for aluminum bodies?I also seem to have a hard time finding steel/aluminum that fits inside stake pockets tightly.Anyone have a special combo?  I'm mostly curious about all aluminum, as I am planning a flatbed build.
Reply:They don't make steel that fits tightly in the pockets. Unless you want to add some metal to em.Millermatic DVIMillermatic 251Older buzz box Cheap 120 welder
Reply:you can buy or make themnorthern tools and even home depotsells them Attached Images
Reply:I make my own stake pockets.  I have a local shop bend me a piece of 1/4" plate 5' long into a C channel shape that is just the right size.  Then I bandsaw it in 2-3" deep pockets.  They end up costing me about $2 each.  They are nice and beefy and just the right size.My name's not Jim....
Reply:Originally Posted by BoostinjdmI make my own stake pockets.  I have a local shop bend me a piece of 1/4" plate 5' long into a C channel shape that is just the right size.  Then I bandsaw it in 2-3" deep pockets.  They end up costing me about $2 each.  They are nice and beefy and just the right size.
Reply:I couldn't touch that here is $50 just to fire the generator up to make the bend. It is way cheaper for me just to get a 5'- of 2x4x3/16 or better yet just buy a 20'-Visions SteelWasilla Alaskahttp://www.facebook.com/album.php?ai...5&l=c32ed1320fwelderstourchessawsgrinders
Reply:Some times I use structural channel, but they won't fit a 2x4 so you have to space them 1/4" or more then butter them up with the mig. OK if you don't have access to a brake or prefabbed pockets."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
GMT+8, 2025-12-24 05:18 , Processed in 0.204871 second(s), 18 queries .
