Blades & Buckets
发表于 2021-8-31 23:57:08 | 显示全部楼层 |阅读模式
What type of welding rod is used to crosweave on outside of  HD  equipment buckets ,earthmoving equipment & etc. ?
Reply:Are you talking about hard facing?Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:my guess would be that he's talking about hardfacing rod...to the OP:You need to know what purpose the hardfacing is supposed to serve...is it for impact? wear resistance? both?What machine are you using?  Is it AC only or AC/DC?  What's it's max amperage?Basically, what are you looking to do?--Wintermute"No man's knowledge here can go beyond his experience." - John Lockewww.improvised-engineering.comManufacturer Agnostic:Blood----------Sweat---------Tears----|------------------|----------------|----Lincoln Red, Miller Blue, Esab Yellow
Reply:If your talking hard rod, Stoody 31 or 35 makes the thickest and most uniform bead of any I've ever used.                               MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Originally Posted by mla2ofusIf your talking hard rod, Stoody 31 or 35 makes the thickest and most uniform bead of any I've ever used.                               Mike
Reply:Originally Posted by starWhat type of welding rod is used to crosweave on outside of  HD  equipment buckets ,earthmoving equipment & etc. ?
Reply:thanks to all
GMT+8, 2025-12-24 05:21 , Processed in 0.099343 second(s), 18 queries .
