My cart for miller 140
发表于 2021-8-31 23:57:06 | 显示全部楼层 |阅读模式
Well I guess I will throw up a thread for my cart. I made a few weeks ago. It is not quite finished but works for now. Its made of 1x2 tube and 1x1 angle iron. I still need to cut a piece of sheet for the bottom, maybe some diamond plate and make a better tank retaining setup. The cheapo chain is just temporary. The rear section for the tank is big enough if i wanted to put a full size bottle on it i could. The rear handle also will double as a tank tip over guard and is/will be removable to aid in tank swaps. I need to hammer out the details on that as well. Overall I am pretty happy with it and it rolls around nicely.Edit, tried to fix pictures. I could not see them. No luck.  Might have made it worse.  Oops.....DavidLast edited by David R; 03-01-2010 at 04:39 PM.
Reply:great job good overall idea.
Reply:Nice to see a new design idea in the cart world.Jack OlsenMy garage website
Reply:Nicely done.*************************************Mike AccardiHenderson, [email protected] 250XLincoln Weldpack HDMiller Syncrowave 180 SD*************************************
Reply:well, it's a nice enough cart.But it's the wrong color. You should have gone RED!!!!heheheJust kidding. Nice job.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Is it just me or is the pic not showing up???Come try it out and stay a while.
Reply:No pic here."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:no pic here either?
Reply:they were their? another thread the attached photos dissapeared also. let me try again. Attached Images
Reply:nice cart,same model 140 I gotDrink a Guinness Draught....Millermatic 140Do you still rememberDecember's foggy freeze --when the ice thatclings on to your beard isscreaming agony.
Reply:That is a nice cart.Get some 2" X 1/8" flat stock and bend it around your tank.  This gives you a half circle as a "cradle" to weld to your uprights if you wanted to add some support for your tank.   I know you already painted but it was just a thought.Come try it out and stay a while.
Reply:Very nice cart, take advantage of that space below with some expanded metal. Can't have to much storage.
Reply:I like the idea, kinda like a shopping cart, wife will love it............
Reply:Very nice. What size cylinder is that? 80cf?Ya gotta spend money to make money!
Reply:Ive got the same welder as yours. i like your cart better though. i need to add ground and torch management then clear coat it.
Reply:Originally Posted by rustywranglerThat is a nice cart.Get some 2" X 1/8" flat stock and bend it around your tank.  This gives you a half circle as a "cradle" to weld to your uprights if you wanted to add some support for your tank.   I know you already painted but it was just a thought.
Reply:Originally Posted by Jimmy_popIve got the same welder as yours. i like your cart better though. i need to add ground and torch management then clear coat it.
Reply:Very nice design and build!  I want to build the same style cart for my Lincoln.What size are your wheels?  I like the spoked rear wheels.  Thanks!
Reply:Originally Posted by karlgabelVery nice design and build!  I want to build the same style cart for my Lincoln.What size are your wheels?  I like the spoked rear wheels.  Thanks!
Reply:i like it too.... a very unique design
Reply:Thanks!
Reply:Jeromy, Nice detail work on the corners and cable racks.  Well done!Miller 211 MIGMiller 375 Extreme Plasma CutterMiller Maxstar 150 STL TIGOxy-Acetylene torch
GMT+8, 2025-12-24 05:20 , Processed in 0.066126 second(s), 18 queries .
