Alfred the Dentist - Teeth crowned and replaced too. Fast service. Guaranteed work.
发表于 2021-8-31 23:56:55 | 显示全部楼层 |阅读模式
Hey Denrep?Yeah Alfred?Denrep, I sure wish we had that diesel-generator running. But I don't feel like pulling the engine just to replace the starter ring-gear.I know Alfred, but we can't chance running it any more with the missing tooth, it'll just get worse; that's why we parked it. Remember?I can't believe it - one stupid starter solenoid malfunction knocked it out of service. Now it's just rotting away.Denrep, the other day when the dentist was fixing my tooth, I had an idea...You know there's a window near the starter mount, that would give accesses to the ring-gear, blah blah blah... What ya think? We've got nothing to lose.Okay Alfred, let's go for it.Attachment 47121Attachment 47122Attachment 47123Attachment 47124Last edited by denrep; 10-19-2010 at 11:44 PM.
Reply:Good Job!..I like how you refer to yourself in the second and third person.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:I often find parallels between dentistry and metal work. Nice work there. You'll have to let us know if it holds up in the long run.
Reply:So would this be considered a root canal or just a cap??? lol Great job
Reply:No polish afterwards?  That's what my dentist does...My name's not Jim....
Reply:Nice!....Miller Diversion 165120 amp Buzz BoxVictor Oxy/Ace Oxy/LPGSmith "Little" Oxy/LPGHypertherm Powermax 30Lot's of Misc. tools n' crap....
Reply:Denrep...    That's a great repair. Can I ask a couple of newby questions?  What type of welder, what type of rod did you use for this.  (Stick, 7018?)  Aren't you worried that the flywheel would crack from the heat?thanx, zip.
Reply:a crowning achievement"Any day above ground is a good day"http://www.farmersamm.com/
Reply:You Hand-shaped an involute gear tooth?  With a file and a handheld die grinder?  Wow.    The best laid schemes ... Gang oft agley ...
Reply:Originally Posted by zapsterGood Job!..I like how you refer to yourself in the second and third person.....zap!
Reply:Good save, which filler did you use? I did a pinion for a dragline turntable using a work hardning Stoody a few years back.Peter
Reply:Originally Posted by zipzit. . .What type of welder, what type of rod did you use for this.  (Stick, 7018?)  Aren't you worried that the flywheel would crack from the heat?
Reply:Diesel Dentures!  Awesome job guys.Good call on the ground clamp location.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:OK rinse and spit, your done.  Good job!jrw159
Reply:good work
Reply:Soooo...... Does it work?  No howling or binding up?My name's not Jim....
Reply:Originally Posted by BoostinjdmSoooo...... Does it work?  No howling or binding up?
Reply:Originally Posted by 59halfstepThere is always a bit of howling when a dentist is involved.
Reply:Originally Posted by DSWYou just need to reach an understanding with him. Reach out with your right hand and get a nice firm grip on whats between his legs, and make sure he understands when YOU hurt, HE hurts!
Reply:I love this kind of stuff man! Fantastic.
Reply:Alfred and Denrep, DDSFamily DentistryWould you like flouride with that?Work HARDER, not smarter! ------------------------ Miller Bobcat 250Millermatic 251Lincoln Precision TIG 185Hypertherm PM 600Hobart 135 HandlerOxweld 400 FlameMaster
Reply:Originally Posted by Leadhead1911Alfred and Denrep, DDSFamily DentistryWould you like flouride with that?
GMT+8, 2025-12-24 06:37 , Processed in 0.105924 second(s), 18 queries .
