6x10 daul axle trailer
发表于 2021-8-31 23:56:54 | 显示全部楼层 |阅读模式
I need help on the placement of axle on a 6x10 daul axle trailer, not sure where to put axle.   help
Reply:It really depends on the intended use.  If it's just general purpose then you could use the 60/40 rule.  Measure 6ft back from the front of the bed and that should be the center of your axles.  If using leaf springs then mount the pivot of the balance bar there and the springs will locate the axles.   If using torsion axles then you have to do a little bit of math to figure out the mount points relation to the center of the stub axle, but it isn't too bad.My name's not Jim....
Reply:Like Jim said, it depends on the axles & suspension you choose. If leaf springs are in the plans, then it is best to get dimensions from the suspension supplier. The measurements between center equalizer and outer spring hangers are specific for each size of spring sets. But the 60/40 rule still applies and will likely be centered on the equalizer mounts. Make certain the mounts are equa-distant from the ball socket at the front for even tracking.http://i.b5z.net/i/u/1080235/f/Desig...iderations.pdfCity of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:I find it works best if you get the round thingys between the road and the trailer deck.
Reply:i was always taugh on anything less than 16ft. to find the center of the frame, and then measure back one inch per foot of trailer frame.AG MECH DUDE
Reply:A 10 foot dual axle trailer seems like it might be a special use trailer, something made for hauling around a skid steer  or small piece of equipment.  Obviously you need more weight on the tongue, but only a few hundred pounds when loaded, depending upon what your truck is capable of handling.  A short trailer with dual axles will pretty much look centered under the length of the trailer betd with maybe an offset from center of 6 inches toward the rear.  The tongue length is not included and you will find that loading and carrying the equipment, the weight will be carried by the trailer axles properly and not all on your vehicle.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:this trailer will carry a  sa-250   oxy/act rig, two 14 x16 x62 inch toolboxes
Reply:Go to championtrailers.com and they have all the information along with trailer plans. A really good site. Like the others said 60/40. I just bought 6X12 tandem axle to replace my 5X8 single axle thats to small. I was looking for a 6X10 but couldn't find one. Heres a picture of mine,(5X8) and when you get yours set up post a pic, it might give me an idea on something I could do differently.Thanks Attached Images
Reply:That's really interesting, I've never seen a green acetylene bottle"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Thanks for your help, nice set on your trailer
Reply:farmersamm, I've dealt with alot of different welding supply companies for the company I work for, and they all have different colored bottles.
Reply:Originally Posted by farmersammThat's really interesting, I've never seen a green acetylene bottle
Reply:My first thought was: "Why does he have two oxy bottles on that trailer, and no gas?"One more reason I shouldn't try to think.
Reply:I've seen green before on those big cylinders....My current color is black.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
GMT+8, 2025-12-24 06:49 , Processed in 0.093475 second(s), 18 queries .
