Small tubing and flat stock roller... free plans included
发表于 2021-8-31 23:56:53 | 显示全部楼层 |阅读模式
To start off, this is not my design. I found it here http://www.tbucketeers.com/topic/693...e-tube-bender/  and modified it to use what I had at hand.Plans are here in pdf format: http://www.mediafire.com/?oxz1y2mojdzThis has been and still is an ongoing project. The only thing left to do is to finish all of the dies I want to make. Those would be round tube sizes 1/2"-1", square tube sizes 1/2"- 1", flat stock the hard way sizes 1/8", 3/16", and 1/4" and a set for flat stock up to 1 1/2" wide the easy way. To start off, all material is 1018 cold rolled steel except the bronze bushings. The drive sprockets and chain were purchased from Farm and Fleet. They are 12 tooth for #35 roller chain iirc.The rolls can be up to 3" in diameter by 1 1/2" wide.continued... Attached ImagesDarwinian evolution used to fix stupid. Now that humans have mostly removed themselves from the process of natural selection the survival rate of idiots has skyrocketed.
Reply:Here is a sample of what the plans look like. Attached ImagesDarwinian evolution used to fix stupid. Now that humans have mostly removed themselves from the process of natural selection the survival rate of idiots has skyrocketed.
GMT+8, 2025-12-24 06:40 , Processed in 0.258540 second(s), 18 queries .
