Cart/Rig for XMT and Dynasty
发表于 2021-8-31 23:56:52 | 显示全部楼层 |阅读模式
Here is something I am throwing together to house a few machines/components. There is an XMT350 CC/CV, Dynasty, S64M wire feeder, multi process selector switch and some other items. The *** end will have a pair of 340cf tanks.It is made from 1.25" DOM tube because I have a crapload of it. Bent it up with my JD2 bender.Hope these pics show. Taken with my phone.Granthttp://jackalopefab.com/ Attached ImagesLast edited by jackalope; 09-21-2009 at 09:11 AM.
Reply:Looks nice Grant.  Nice shop also!  How top heavy is that cart going to be?
Reply:I want to see that trailer thats over in the corner. It looks nice...If you cannot convince them, confuse them.         Harry S Truman
Reply:I don't have any recent pics of the trailer, but there is one on my website http://jackalopefab.com/    go to the "equipment" section and click on the Bobcat.That pic is probably 2 or 3 yrs old. It is now outfitted with a SGA100C remote so I can run spoolgun off of it. There is also O/A tanks and CO2 for the MIG. On the front there is a diamond treadplate box for tools and some other odds and ends.There used to be a thread on Hobarts site some time back. I will try to track it down and then post the link here on edit.Granthttp://jackalopefab.com/MM210Synchrowave 200DXMiller XMT350 w/60series feederMiller Bobcat 250 with SGA 100 and spoolgunHTP PlasmaFull Machine shop with everything
Reply:Here ya go. 2005! Man, I did not realize it was that long ago.http://www.hobartwelders.com/weldtal...ht=gde+trailerhttp://jackalopefab.com/MM210Synchrowave 200DXMiller XMT350 w/60series feederMiller Bobcat 250 with SGA 100 and spoolgunHTP PlasmaFull Machine shop with everything
Reply:Ponch,  As for stability, it is very stable believe it or not. It takes a considerable effort to even get it to move side to side. It is more than 25" wide from side to side. Once there is a piece of plate across the bottom, it will be so heavy and low COG, it would take a plow to tip it over!Granthttp://jackalopefab.com/MM210Synchrowave 200DXMiller XMT350 w/60series feederMiller Bobcat 250 with SGA 100 and spoolgunHTP PlasmaFull Machine shop with everything
Reply:I just checked out your website, great work and really nice toys in the shop!
Reply:Looks nice.   No wheels??MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Originally Posted by DesertRider33Looks nice.   No wheels??
Reply:Here are some updated pics of progress. I worked on it for about an hour last night while waiting on a customer.I had some questions re: cantilever for tanks. You can barely tell in the blurry pics, but the plate the tanks sit on is about 1/4" off the floor. I ought to install a broom/brush in front of it as it will act as a plow! Attached Imageshttp://jackalopefab.com/MM210Synchrowave 200DXMiller XMT350 w/60series feederMiller Bobcat 250 with SGA 100 and spoolgunHTP PlasmaFull Machine shop with everything
Reply:Hey I did a search on process selector switch and this came up.  Does anyone know that if they all or only some have a solenoid in it?  I want to use my xmt 304 cc/cv as a tig welder but don't want a valve on the torch.  I found one online, I think this is the part number...p/n 042872also there is a link on the ad that goes right to miller with a full description  http://www.millerwelds.com/om/o817e_mil.pdf    Yet there is not one mention of a solenoid.  Apparently I can have this one for $90 and according to the ad they go for $814.  Seems wierd there would be such a price drop but I don't know much about these.  Can anyone help?  thanks
GMT+8, 2025-12-24 06:31 , Processed in 0.102365 second(s), 18 queries .
