查看: 13|回复: 0
another plasma cutting question
发表于 2021-8-31 23:56:51 | 显示全部楼层 |阅读模式
if cutting outside, can a moderate breeze affect the cutting ability of the plazma gun, I think that is what was happening the other day but not sure.  the cuts started to degrade using a drag tip, but the tip looked o.k. from 1st observation.thanksRon
Reply:If it is an air plasma I don't think a breeze can affect it. Buy you might want to check and see if your air supply pressure is constant. A drop in pressure will affect the cut.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:I had done that and the air was good but the cut had become degraded when the wind picked up.  I have not had a chance to recheck since the last cut and thought I would get more response,and also thought I might hear from the plasam guru here.
Reply:The wind around here blows hard enough to make you shake,even hard to stick weld weld when it gets going.
Reply:That must have been a cold hard wind. The air coming out the end of the tip at 70/75 PSI input is about 20,000 FPS and at about 30,000 degreese. What amps were you runing and how thick and what kind of metal was you cutting???????www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:I don't believe you will ever find a wind strong enough to affect a plasma cutting arc. As Mechanic stated...the power and velocity of the arc will overcome any wind or temperature issue.Jim Colt   Hypertherm
Reply:Thanks Jim and others for the response , it might actually be the tip I didnt have time the other day to do a thorough checking of the tip, however they were cutting a very old piece of metal that had been been painted so right now i think a consumable was wasted.ThanksRon
Reply:Id be willing to be the tip is shot way more than the wind effected anything.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Me to I just didnt get to check it today,but hope to tomorrow.  I Bet.......2bits
GMT+8, 2025-12-24 08:10 , Processed in 0.134275 second(s), 18 queries .
