Welding of 8620
发表于 2021-8-31 23:56:48 | 显示全部楼层 |阅读模式
What process are needed to weld cast 8620 to ASTM A500 Grade B structural tubing.  I am looking for reasons comparing 1045 cast vs 8620 cast material.
Reply:Since I don't know those alloys off hand,  I would look up the material chemistry, calculate the carbon equivalent (CE), and if it was above about 0.35 % I would consider preheat, postheat, and a low hydrogen process. 1045 is plain carbon steel with 0.45 % carbon so it is hardenable enough to have potential problems with heat affected zone brittleness and cracking, unless the weld is preheated and welded with low hydrogen techniques.  I would also consider the application, is it something involving high stress, impact, vibration, life/death?
GMT+8, 2025-12-24 06:31 , Processed in 0.206686 second(s), 18 queries .
