AC Tig-Sharp Point-2% Thoriated-before & after pics
发表于 2021-8-31 23:56:42 | 显示全部楼层 |阅读模式
AC Tig-Sharp Point-2% Thoriated-before & after picsI took these pic's, last week to show-the ability of an inverter to maintaina sharp point on 2% thoriated tungsten on AC--which focuses the arc (and thus the heat), not letting the arc dance around, allowing easy welding in corners, in addition to welding quicker and hotter than the 'normal' method of  using pure tungsten with a nice ball to spread the out the heat, dance all around,consuming more time and gas, with significantly more power required.I'm posting this simply to help illustrate what can be done, not to ignite another great debate over transformers vs. inverters.Setup: T-D 300 GTSW, 150a max, 80 cps, 15% balance, pure Argon, C-K flex loc torch, #7 gas lens, 1/8" 2% thoriated tungsten15 min's. arc-on laterBelow, the work involved welding 4 reinforcement plates to the already repair welded handle. This is an internally dirty casting. A center plate with a hole is added, later; after beveling.This is not a make pretty, job---it's a make stronger job. The initial welds shown get ground, carbide burred, then more welding and fairing from the plates to the casting. Yes, I know there's some 'suck holes'--those get beveled out, etc.Blackbird
Reply:Man I can't wait to get a tig!Thanks for the tips and pics - some of which it appears you forgot to re-size btw.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:You are much steadier than I.  Thank you for doing that.David Real world weldin.  When I grow up I want to be a tig weldor.
GMT+8, 2025-12-24 06:56 , Processed in 0.094448 second(s), 18 queries .
