used breaker point for an anvil or????
发表于 2021-8-31 23:56:39 | 显示全部楼层 |阅读模式
I changed this point out a while back and decided to save it, I was thinking of using it as kind of an anvil, whata think?, any other ideas? Attached Images"Obstacles are those frightful things you see when you take your eyes off your goal"   -Henry Ford
Reply:What did that come off of? I have never seen one with that lip and made hollow. The biggest problem withhitting on a breaker is the fact that it is usually harder than the hammer, I had a piece of hammer go through my hand trying to jar one loose to change one out. Just something to think about....Aeromax Service Truck w/ 6,000lb Crane to carry my toys.Miller Trailblazer 302'69 Lincoln SA-200A couple of Victor Jr's to make big pieces smaller..........
Reply:wow!whats that weight?I would cut the end off for drainage...bury it in the front yard and plant flowers in it... Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:other ideas?  Condom for the few, the proud etc... just a thought, been like this all day, sheesh.Lincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:I was thinking it would make a good cone anvil for working on rings, but it would really need a nice smooth round taper to make that work. Lots of welding and grinding to do that it looks like..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by Pipeline MechanicWhat did that come off of? I have never seen one with that lip and made hollow. The biggest problem withhitting on a breaker is the fact that it is usually harder than the hammer, I had a piece of hammer go through my hand trying to jar one loose to change one out. Just something to think about....
Reply:Originally Posted by John Twow!whats that weight?I would cut the end off for drainage...bury it in the front yard and plant flowers in it...
Reply:Launch it at evil law makers?       Sincerely,             William McCormick
Reply:make a wind chime/wind gong out of it for the backyard Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:I am more accustomed to these, they will gal in underwater use. The contractors do not care just run themtill they quit and we fix em so they can do it again. SOmetimes a tap with a big hammer will slide it backto get slack in the pin and then fire it out. Change the bushing, new bull dick and send them out again.Aeromax Service Truck w/ 6,000lb Crane to carry my toys.Miller Trailblazer 302'69 Lincoln SA-200A couple of Victor Jr's to make big pieces smaller..........
Reply:a chair.?  if u have someone hangin around your shop to long and want them gone...tell them to have a seat , and point at that.        thermal arc 252i  -  millermatic 350P -   miller XMT, cp300ts, 30a 22a feeders, buttload of other millers, handfull of lincolns, couple of esabs  -   Hypertherm 1250 G3
Reply:Second on the wind chime idea. Or if you're feeling spunky, put some black powder under it and see how high it flies.
Reply:Originally Posted by Grimm1 put some black powder under it and see how high it flies.
Reply:I'm glad you found that video, thats the one that gave me the idea.
GMT+8, 2025-12-24 07:03 , Processed in 0.092870 second(s), 18 queries .
