looking for a supplier
发表于 2021-8-31 23:56:39 | 显示全部楼层 |阅读模式
So, I've exhausted my list of suppliers and search capabilities.  I need to find a place to buy two 9 foot long precision moly or stainless steel tubes with a 1.5" OD and a wall thickness of between .125" and .250".  I can obviously find standard tube in this size, but I actually need precision tubing.  This tube will be used as a light weight pair of linear guides (using round linear guide bearings) which is why standard 1.5" OD tube won't work.  I want either stainless or moly so that I don't have to deal with too much surface rust over time (moly is fine since it's at least a bit more rust resistant than carbon.Does anyone know of a supplier who can get this?  So far the only place I've found that could get it will only deal in bulk purchases (basically, 2,000lbs or more) which comes out to about 1,980lbs more than I would actually need.Thanks in advance if anyone can help --Wintermute"No man's knowledge here can go beyond his experience." - John Lockewww.improvised-engineering.comManufacturer Agnostic:Blood----------Sweat---------Tears----|------------------|----------------|----Lincoln Red, Miller Blue, Esab Yellow
Reply:special metals of oklahoma city 405-677-7700, should have it in dom tubing
Reply:Originally Posted by weld4youspecial metals of oklahoma city 405-677-7700, should have it in dom tubing
Reply:ill also check down at my shop, i might have it in 4140, or stainless.
Reply:If you gotta gotta gotta have itGive this dude a shout.  Not cheap, but does have a lot of stuff.And he sends you cool little stickys with the order Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:sells in any length, not like the big guys, where you have to almost buy a truckload"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Nice, thanks guys.  Weld4u, if you have some available, let me know what the cost + shipping will be and I'll get if from you.  If not, I'll try the two places posted and see what I can get Thanks again! --Wintermute"No man's knowledge here can go beyond his experience." - John Lockewww.improvised-engineering.comManufacturer Agnostic:Blood----------Sweat---------Tears----|------------------|----------------|----Lincoln Red, Miller Blue, Esab Yellow
Reply:On this same note what about copper sheeting? I'm needing a 32x48 thickness doesn't matter to much thinner the better as it will be bent around a round itemMillermatic DVIMillermatic 251Older buzz box Cheap 120 welder
Reply:Originally Posted by wintermuteSo, I've exhausted my list of suppliers and search capabilities.  I need to find a place to buy two 9 foot long precision moly or stainless steel tubes with a 1.5" OD and a wall thickness of between .125" and .250".  I can obviously find standard tube in this size, but I actually need precision tubing.  This tube will be used as a light weight pair of linear guides (using round linear guide bearings) which is why standard 1.5" OD tube won't work.  I want either stainless or moly so that I don't have to deal with too much surface rust over time (moly is fine since it's at least a bit more rust resistant than carbon.Does anyone know of a supplier who can get this?  So far the only place I've found that could get it will only deal in bulk purchases (basically, 2,000lbs or more) which comes out to about 1,980lbs more than I would actually need.Thanks in advance if anyone can help --Wintermute
Reply:Originally Posted by dave powelsonWHOA!---.  "This tube will be used as a light weight pair of linear guides (using round linear guide bearings) which is why standard 1.5" OD tube won't work."So before anybody else gets all nervous and excited---the OD of this tube has to becenterless ground and polished to a tolerance of __________, in order to fit the inside of the linear bearings.So what is the tolerance range of these linear bearings??That's kinda critical.BTW---for linear ways (that's what you're actually describing), Thompson and othersnormally use heat treated, ground and polished, solid round bar--to minimize deflection,etc.---which can be a bunch in a 9 footer. They also sell what you're trolling for.
Reply:Since you're asking/looking for sources for 'precision tubing',to fit linear bearings, I would suggest that you consider your requirements for:-size---you stated 1.498-1.502 OD--surface finish ? --(microinch)-straightness ?-roundness ?-presence of dings, dents, marks?-packaging for shipment ? (crating is needed)All of the above, normally imply the use of ground stock, unless you can finda vendor that will commit to the above, in writing, contracturally.Blackbird
Reply:Originally Posted by dave powelsonSince you're asking/looking for sources for 'precision tubing',to fit linear bearings, I would suggest that you consider your requirements for:-size---you stated 1.498-1.502 OD--surface finish ? --(microinch)-straightness ?-roundness ?-presence of dings, dents, marks?-packaging for shipment ? (crating is needed)All of the above, normally imply the use of ground stock, unless you can finda vendor that will commit to the above, in writing, contracturally.
Reply:Originally Posted by wintermuteThe surface finish of all precision tubing is fine enough to work for what I need.  Roundness as well.  If there's a dent...well, yeah, that's an issue, but one I would have to deal with in replacing that rail.  Straightness, much the same as deflection for an issue, and some is acceptable to me with the capability to straighten the tube while in it's tensioned position.I understand that you are trying to help, but I've done the analysis that I need to do.  I will be laser mic'ing both tubes after they are recieved and if I need to change the specifics of the bearings, I can.  --Wintermute
Reply:Originally Posted by dave powelsonI'm simply trying to alert you, that cold drawn or dom tubing can and does have all mannerof glitches; especially if just pulled out of a stock rack, taped together, run over by a forklift,then thrown into a 48' trailer! ----(been there & had that dun to me)          I thought precision implies just that--as in ground, sized, specially handled, etc.   ......"if I need to change the specifics of the bearings, I can." ??????Are you using composite bearings and re-sizing them? If so, I'm interested.
Reply:$18.00 per foot FOB Seattle
GMT+8, 2025-12-24 08:37 , Processed in 0.110368 second(s), 18 queries .
