I need to make a gate for my driveway, prob 12 ft swinging gate 3 ft high. will be made from 2x2 1/8 box. How do i hinge it? Where do i get hinges? Thanks--scottMiller Thunderbolt 225Millermatic 135harris oxy/propane torch
Reply:I buy my hinges at my local metal supplier. They sell very heavy duty barrel hinges that you weld on. They have brass bushings as well. Let me go snap a picture and show you. I will post up quick.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:These are the ones I use. They have a flat side for welding onto your gate and your post. If you weld them in the same orientation as in the pin pointint up, you can lift the gate up and off the hinges for repairs or replacement. If you welt them in opposed orientation, one pin up and one pin down the gate will have to be cut off. Maybe better for security.....Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Check out King Metals website, these already pictured, and more, are available there.
Reply:Originally Posted by sreachardI need to make a gate for my driveway, prob 12 ft swinging gate 3 ft high. will be made from 2x2 1/8 box. How do i hinge it? Where do i get hinges? Thanks--scott
Reply:Thanks everyone, I'll check kings website out.pics..........lets see how it turns out first! there is some nice work on here, mine probably goes in the what not to do thread!this won't be anything fancy, just need something to keep my kids from riding their bikes into the street.Miller Thunderbolt 225Millermatic 135harris oxy/propane torch
Reply:You might want to post a sketch of what you're planning here. 1/8" 2x2 might be overkill for the application, making the gate more prone to (weight) sag and possibly more likely to hurt a kid. Also maybe mention what you're attaching it to -- a pole you're sinking into concrete, or an exisiting wall, or what.Jack OlsenMy garage website
Reply:Yeah, those Bullet Hinges are great.... You can get them in Stainless, Aluminum, etc.../J....Miller Diversion 165120 amp Buzz BoxVictor Oxy/Ace Oxy/LPGSmith "Little" Oxy/LPGHypertherm Powermax 30Lot's of Misc. tools n' crap....
Reply:you can also check out northern tool, they have all sorts of weld and bolt on hinges including the bullet hinges starting at like 4 bucks a pop.Miller Dynasty 300 DXMiller CST280Miller Maxstar 150 STH
Reply:go to tractor supply and get a cattle gate 12 foot there are light
Reply:I'll see if i can do a drawing of some kind. The gate won't be anything elaborate. After talking to the wife and doing some measuring, where i wanted to put it would have been a 12 ft gate. Where she wants to put it will be 20 ft, so I'll be building 2 10ft gates. Yes, they will attach to 3x3x3/16 set in concrete. I researched some on some gate mfg websites, looks like 3ft deep with outriggers is how they do it. Does that sound right? The only reason I was thinking 2x2x1/8 is because i have a bunch of it sitting here. the gates will be simple, 10ft x 3ft rectangle braced in the center with some chain link filling in the open area. ThanksMiller Thunderbolt 225Millermatic 135harris oxy/propane torch
Reply:look at king first and then compare if you only need 4 it might be worth buying localbut you can get an idear what you need for size and weight from king
Reply:I would honestly put your posts atleast 6 ft deep and as big as you can make your holes. (width wise) You never know what you might want one day. I'm a contractor and do it this way easier to over build than underbuild. I try and plan for the unexpected. You might want a 6 foot tall fancy gate down the road.Millermatic DVIMillermatic 251Older buzz box Cheap 120 welder
Reply:Originally Posted by sreachardthe gates will be simple, 10ft x 3ft rectangle braced in the center with some chain link filling in the open area.
Reply:Man,there is a lot of nice stuff on that king website.. Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221 True Wisdom only comes from Pain.
Reply:Originally Posted by John TMan,there is a lot of nice stuff on that king website..
Reply:King metals fo sho...MILLWRIGHT'S SONMiller XMT 304 CC/CVMiller S52 Stainless Steel FeederMiller Process Selector ControlBernard Q-GunBernard Short StubTrade: Furniture Maker, so I'm a fabricating fool.
Reply:I had this style recommended for my gate project by one of my welding professors, who also runs his own business making fences and gates.The weight rating is there, and they are adjustable which is very important because over time, all gates sag.http://www.kingmetals.com/default.aspx?page=item detail&itemcode=44-2005-ADJ Attached ImagesCity of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny |
