查看: 13|回复: 0
Double Holy Crap !!
发表于 2021-8-31 23:56:37 | 显示全部楼层 |阅读模式
IT'S..........................................YELL  OW!!To be precise.....Sherwin Williams Safety Yellow Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:oww! my EYES!!!!!!-- fredLincoln 180C MIG
Reply:That's one heck of a solid state night light Samm --Wintermute"No man's knowledge here can go beyond his experience." - John Lockewww.improvised-engineering.comManufacturer Agnostic:Blood----------Sweat---------Tears----|------------------|----------------|----Lincoln Red, Miller Blue, Esab Yellow
Reply:Samm,You'll never bump your leg on it in the night that's for sure...Just thinking, with all that metal and all those metal projects you have going on, you ought to at least put you up a metal pole shed to get you out of the elements and give you a place to poke around in on a rainy day.   It really shouldn't be too much.  Around here you can by mixed "second" tin to cover the top, and for the sides, you could take a couple of old shipping containers and strip the metal off of them.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:WOW, that is 'indeed' YELL OW !  Damn thing looks great though, doesn't it ?  How many coats do you think it'll take..?Cheers,/J...Miller Diversion 165120 amp Buzz BoxVictor Oxy/Ace Oxy/LPGSmith "Little" Oxy/LPGHypertherm Powermax 30Lot's of Misc. tools n' crap....
Reply:Was that paint in the "70% off" stack?
Reply:Even Stevie Wonder would see that!MikeConstans Fides et IntegritasLincoln Weldanpower 150 ACAirco Aircomatic MIGet CAV II w/ spoolgunMillermatic 30a wirefeeder
Reply:Yep, looks "safe" to me..............Larry "I feel for the man who cannot spell a word more than one way."  by Mark TwainLincoln AC225-SLincoln Weldpac 100 Miller Matic 180 (auto set)Miller Spectrum 375 ExtremeMiller Spoolmate 100Victor Super Range II
Reply:looks great did you use a roller or spray gun
Reply:Looks great but where are the girls?Dave ReberWadsworth Ohio
Reply:...so...on your in-out saw table there...looks like OSHA yellow to me...I've had to fab. and install several guard railings around press-brakes and punch-presses at my job...OSHA says it WILL be yellow.....  Rust-o-leum even makes an OSHA yellow...Dougspair
Reply:I love yellow for tools and equipment. Looks great.        Sincerely,             William McCormick
Reply:William McCormick I have to laugh when I see camo colored tools. Lay it down once and never find it again or until the brush hog finds it.Dave ReberWadsworth Ohio
Reply:did someone say "tools"????? Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Thank you You make me smileDave ReberWadsworth Ohio
Reply:Probably is an OSHA approved color, can said "safety yellow", but I didn't read the fine printEd.......used a spray gun, pressure around 50-60psi due to the wind.  Four coats, thinned probably near on 60% paint, 40% mineral spirits.  High thinner ratio allows you to put a coat on and it doesn't fully flash between coats in high wind.  You still have a good semi tack coat to paint over on the second go around.  If not fully flashed, the next coats will blend into the previous coats without overspray marks.  Mineral spirits is a "slow" thinner, and works well outside"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Overlap your passes, half the spray pattern should be on the previous pass.First coat should be a mist coat.  Don't try to hide the primer with the first pass.  The first pass is merely to give a "tooth" for the subsequent passes to adhere to.All the later passes are made to build the finish.  A little slower, but not too slow, you can get sags.Smoke a cigarette, or eat a candy bar, between passes to allow the thinner to flash.  Painting over insufficiently flashed coats can lead to orange peel.  The next layer seals the thinner in, and it trys to bubble out from underneath it when it evaporates."Any day above ground is a good day"http://www.farmersamm.com/
Reply:What kind of spray gun do you use?HH 187Miller Bluestar1EAHP AlphaTig 200X
Reply:she sure is yellowLeighLincoln Classic 300DLincoln SA 250Red d arc 300 dieselRanger 305Miller 302 Trailblazer12V Extreme SuitcaseMiller 200 DXVictor O/A torches3 dodge dually cummmins
Reply:Looks like every piece of ground support equipment I am responsible for maintaining....13538 Government Yellow!Miller Thunderbolt AC/DC (Sold)Miller Dialarc 250HFMiller MM251Miller MM200 (Sold)Miller MM130Miller Spot WelderVictor O/A rigMiller Spoolmatic 1 (Sold)
Reply:i think i saw that on satellite imagery
Reply:Originally Posted by farmersammOverlap your passes, half the spray pattern should be on the previous pass.First coat should be a mist coat.  Don't try to hide the primer with the first pass.  The first pass is merely to give a "tooth" for the subsequent passes to adhere to.All the later passes are made to build the finish.  A little slower, but not too slow, you can get sags.Smoke a cigarette, or eat a candy bar, between passes to allow the thinner to flash.  Painting over insufficiently flashed coats can lead to orange peel.  The next layer seals the thinner in, and it trys to bubble out from underneath it when it evaporates.
Reply:. . .as the lazy March sun slowly set in the western ski, a bright yellow glow like that of the Northern Lights mixed with a pale hue of blueish gray danced overhead in the directon west of Tulsa. . .MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:You're going to have to keep your eyes open. Chicks might come by in camo and you might not notice.
Reply:Originally Posted by duaneb55. . .as the lazy March sun slowly set in the western ski, a bright yellow glow like that of the Northern Lights mixed with a pale hue of blueish gray danced overhead in the direction west of Tulsa. . .*** Note to self:  Sunglasses.  Definitely sunglasses ... the darker, the better.  NOTED ***Yup, that's yellow, all right.  Maybe an OSHA-approved red for the saw?Off-topic, but along the same lines (yellow): my father used to work for Browning-Ferris Industries (BFI) back in California.  One day, the boys in the paint shop were told to paint one of the forklifts yellow.  So, being the smart guys they were, thy did exactly that.  Not the usual Caterpillar Mustard Yellow (or whatever it's called), but the bright, screaming holy-crap-my-eyes-are-melting OSHA Canary Yellow, the same yellow used on the cement poles in the parking lot so people will (supposedly) see them easier.  The damn forklift literally almost glowed in the dark!  Anyway, right as they finish painting, the boss walks out and sees it ... not the shop boss, the BIG boss, as in the owner of the company.  The paint wasn't even dry yet, and the boss's exact words were, "Repaint that  thing NOW."  Needless to say, it got repainted real quick .....
Reply:Where do you put the batteries?   Man that sucker is bright...   Sam, you may not have a need for a tube notcher, but your creation has me thinking hard.
GMT+8, 2025-12-24 07:14 , Processed in 0.107222 second(s), 18 queries .
