What's the best shade number for welding glass attached to a webcam which is used to
发表于 2021-8-31 23:56:36 | 显示全部楼层 |阅读模式
I am trying to use a webcam (Logitech Quickcam Express) to take pictures of the Sun throughout the day for one of the projects I am working on. In order to protect the camera lens from being burnt by the direct sunlight, I think it might be a good idea to place a piece of welding glass in front of the camera. However, I need to determine the optimal shade number of the welding glass for my particular application. Does anyone know what shade number(s) I should choose? Thanks.-----------------------------------------------------------------------------------Mig Welding
Reply:Have you tried a number 4 shade?
Reply:This may be an answer.http://www.muggyweld.com./index2.html
Reply:zeb,You have very little chance of damaging the camera pointing it to the sun. If the camera has a manual iris, adjust it to get the image that you want.ChrisLincoln Pro Mig 180TMiller Spectrum 375
Reply:Originally Posted by transitThis may be an answer.http://www.muggyweld.com./index2.html
Reply:A shade 10 lens is ideal for looking at the sun around a solar eclipse (although no shade is needed during the eclipse totality).
Reply:Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
GMT+8, 2025-12-24 06:55 , Processed in 0.112541 second(s), 18 queries .
