Pipeline and Rig Welding
发表于 2021-8-31 23:56:34 | 显示全部楼层 |阅读模式
If anybody knows where I can go to work right now in the u.s. please let me know im pretty much up for anything as long as im keepin me and my rig working full time. Thanks for any info.- Rex 903-738-5525 or [email protected][/SIGPIC][/SIGPIC] Get the money while its there
Reply:[/SIGPIC][/SIGPIC] Get the money while its there
Reply:Nice looking rig... How do you have your reels mounted, looks like a pipe rack???
Reply:Thanks, I know most people mount there reels by clamping to the amature of the machine but since I run a 250D there was no easy way of doing that so I just bolted angle iron on the corners of the machine and welded a stainless steel pipe frame onto it to come around in front of the armature. Its worked good so far, and makes it easy to skid up on a pipeline.[/SIGPIC][/SIGPIC] Get the money while its there
Reply:nice rig.did you make it?gee your rear tires are close to your arches....do they hit?G
Reply:I have an adjustable air bag suspension to be able to haul my 38' fith wheel camper without it rubbing the fenders. It makes it nice with the bed being that low because i do alot of fabrication work.[/SIGPIC][/SIGPIC] Get the money while its there
Reply:Tis a nice looking rig.I'd rather be hunting........USE ENOUGH HEAT.......Drifting around Aussie welding more pipe up, for something different.....wanting to get home.
Reply:you might check with Systems Contracting in Eldorado Arkansas to see if they need any Rig welders. They have a few NG chiller and compressor stations in the works i think.They dont like prima donnas though. Great company to work forinsert thoughtful quote from someone else2000 Thermal Arc 300GTSW 3.5 hours1946 Monarch 20 x 54 Lathe1998 Supermax 10x54 Mill2004 Haco Atlantic 1/2" Capacity Lasernot mine but i get to play with it
Reply:Just moved to Tennessee colony  near Palestine last July . I have Ben pipe welding for around 15yrs   . Looking for some work for my truck .  Compressor station pipeline where I want to be plant and tank farm where I worked for the last 15 yrs .I can tig stick up hill down hill weld whatever . Can somebody please give me some leads on  work around here or surrounding areas I can travel 9039223781 .
Reply:Originally Posted by trahan76Just moved to Tennessee colony  near Palestine last July . I have Ben pipe welding for around 15yrs   . Looking for some work for my truck .  Compressor station pipeline where I want to be plant and tank farm where I worked for the last 15 yrs .I can tig stick up hill down hill weld whatever . Can somebody please give me some leads on  work around here or surrounding areas I can travel 9039223781 .
Reply:hey trahan76....you just revived a thread thats 3yrs old....might be better to delete and re-post your own? any ways, it might also be easier for you to find a rig job over on RIGWELDER.COMgood luck!
Reply:Contact a local community college that has welding, they usually have good tips on jobs.Miller Performance AD Helmet - Camo Edition Soon to have: Jackson HSL 100 - Forest Digi CamoMiller Thunderbolt AC/DC((Currently at welding school))
Reply:Derp.  Nevermind.
GMT+8, 2025-12-24 06:58 , Processed in 0.092234 second(s), 18 queries .
