I just bought a dc welder TIG?
发表于 2021-8-31 23:56:32 | 显示全部楼层 |阅读模式
I just bought a shop load of tools and in it was a ac dc lincoln welder but it has a tig torch and bottle of 100% argon with it. but it is hooked directly to the welder. I always thought the HERTZ box was also needed to do this not straight from the welder.
Reply:HERTZ box? I'm assuming you mean a high frequency box.A high frequency box is usually only needed if you plan on using a regular SMAW (stick) power source as a GTAW (TIG) power source and want to have non-contact start for DC welding and/or use AC current for aluminum welding.From what it sounds like the machine you have was designed as a GTAW machine and probably has the high frequency function built in.It would be easier to confirm this if you could post pictures of the machine and/or the model number.EDIT: I meant to add that if you meant to buy a SMAW machine, chances are the GTAW machine you have can be used for stick welding.Visit Tensaiteki.com
Reply:ok here is what I can seen on it lincoln AC/DC 225/125 CA/CC(ithinkca/cc is just french) 79V max  specification W352-304. now this thing is at least 50lbs. heavier than my reg lincoln stick welder. will post pics once battery is charged for digi cam
Reply:as far as I know its just an ac/dc stick welder.
Reply:never mind I found the tig welder in the load of tools lol
Reply:Originally Posted by kneedeepnever mind I found the tig welder in the load of tools lol
Reply:can do once I get it all home lol have to get through it all. guy baled on the rent left all of his tools. wifes uncle owns the shop sold me the tools to put toward the rent owed
GMT+8, 2025-12-24 07:04 , Processed in 0.100200 second(s), 18 queries .
