cheap tig welder
发表于 2021-8-31 23:56:31 | 显示全部楼层 |阅读模式
hey guys,a tig torch, a disposable bottle of gas and i've got myself a cheap tig welder? i dont need industrial strength welds, just sum lil fab work such as pipes, aluminum etc. In general will it weld?thanks
Reply:Dan,Welcome to the Forum but your Post is a bit cryptic.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Yeah what Brocc said. With what you described you still need a machine, hoses, a regulator and welding helmet. For starters. And the list goes on and on.Miller Thunderbolt 225Millermatic 130 XPLincoln HD 100 Forney C-5bt Arc welderPlasma Cutter Gianteach Cut40ACent Machinery Bandsaw Cent Machinery 16Speed Drill PressChicago Electric 130amp tig/90 ArcHobart 190 Mig spoolgun ready
Reply:ok thanks guys delete thread
Reply:Some people just can't be helped.WeldingWeb forum--now more sophomoric banter than anything else!
Reply:1.  Cheap2.  Tig3.  AluminumPick any two of the three.... but you can not have all three...
Reply:Actually, I dont think "cheap" and "aluminum" are ever on the same list.You can use any DC power supply, like a stick welder, to do scratch start tig on ferrous metals, or copper alloys.You just need an air cooled scratch start tig torch with a gas valve on the handle, and a tank of argon and a regulator or flowmeter.An aircooled torch like that is about $150, and you can use a mig regulator for the argon or buy a new one. So yeah, you can do some tig welding cheap.Its harder to do scratch start than HF start tig, and depending on what you are doing, you might have a shorter duty cycle when the torch gets too hot to hold, but it will work fine.Aluminum, though, is a whole nother ball game, and about the cheapest way to do that is a spoolgun.Tig welding aluminum means an AC welder, and unless you are really skilled, an HF unit, and probably a water cooled torch.
GMT+8, 2025-12-24 06:59 , Processed in 0.115053 second(s), 18 queries .
