I was thinking about getting the 6291 mask because I don't need anything more, but a reviewer (for the 7502) on Amazon had this to say:"I've been using 3M's 6000 series halfmask with P100 2091 cartridges. I was still inhaling a lot of gas and smoke because the 6000 series has a vent right in the middle and the only thing separating me from the outside air is a thin rubber membrane in the vent. Not so with this respirator. Notice the shield on the center section. It covers that vent, and it makes a huge difference. I also switched to the P100 2097 cartridge, which has the Nuisance level Organic Vapor protection. Boy, what a difference! I am now unable to smell ANY welding fumes while welding. This respirator is also made of a thicker silicone and has a much more comfortable fit than the 6000 series. All in all, a little more money for a LOT more safety, and it all fits under my welding helmet perfectly."Has anyone else had problems with fumes or odors with this mask? I thought the 7502 was just supposed to be a little more comfortable than the 6291, but not filter any more out.Thanks
Reply:Yesterday, I ordered a 3M 7500 series mask on the recommendation from a real lunkhead on here named tbone550. He said the exhilation valve points down to help keep from fogging your hood. It sounds correct. Normally, I would just mosey on over to his shop and help myself to his. But this is sort of a "personal" item that I don't want to share his snot with!I also ordered the 2097 filters. After talking to 3M, I was under the impression that the 2091 and 2097 stopped the same vapors and such. The 2097 has a charcoal filter added to block odors, ie. rotten dead bodies. But I really like the smell of 6010!"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Originally Posted by Stick-manYesterday, I ordered a 3M 7500 series mask on the recommendation from a real lunkhead on here named tbone550. He said the exhilation valve points down to help keep from fogging your hood. It sounds correct. Normally, I would just mosey on over to his shop and help myself to his. But this is sort of a "personal" item that I don't want to share his snot with!I also ordered the 2097 filters. After talking to 3M, I was under the impression that the 2091 and 2097 stopped the same vapors and such. The 2097 has a charcoal filter added to block odors, ie. rotten dead bodies. But I really like the smell of 6010!
Reply:I was late to get back to this forum because of exams. Thanks for the feedback. I have some time to think about it, but I might just go with the 7500.
Reply:Originally Posted by tbone550...My boogers are white as the driven snow in the evenings. |
