generator handle..
发表于 2021-8-31 23:56:16 | 显示全部楼层 |阅读模式
Not sure if it was posted on this board or not...I am looking for a picture of a fold down handle for a portable roll around generator..  something that will fold down when not in use,pull it up when you want to wheel it around...any ideas please ..thanks. Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:weld some tabs on the frame  and bolt some pipe to them with tabs on the top and that should workLincoln Pro Core 125Lincolin sp 100Miller Big 40Lincoln Idealarc SP250miller matic 212http://www.facebook.com/hdwelding?sk=wallwww.hdweldingbeds.com
Reply:Originally Posted by heimbuckweldingweld some tabs on the frame  and bolt some pipe to them with tabs on the top and that should work
Reply:Have you looked at lawn mower handles? I have one customer, that due to space requirements, always folds their mower handle up for storage.My other thought would be slide out pipe handles. We have them on our big wetsaw, Basically a pipe in a tube and a screw to lock it. Slide it out and use it like a wheelbarrow..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by John Tyeah..thats what I envisioned...was just looking for a picture..actually good to figure things out 4 yourself ...I'll be working on that 2-morrow.
Reply:Originally Posted by SandyWere you looking to see handles just like most of the factory portables come with or did you have something else in mind ??
Reply:all the ones I have seen are like this,imagine 2 flatbar tabs about a 1.5" long welded to the main frame, then about a 1" pipe is bolted between the two, a second hole in botht the flatbar and pipe is drilled, when you pull the pipe up you line the holes up and slip in a tractor pin about 5/16"  when you want it down you pull the pin, I hope this helps
Reply:generator handle..Not sure if it was posted on this board or not...I am looking for a picture of a fold down handle for a portable roll around generator..something that will fold down when not in use,pull it up when you want to wheel it around...any ideas please ..thanks.
Reply:Here is a pretty simple onehttp://titanindustrial.com//i/invphotos/7500d.jpgits on the left side
GMT+8, 2025-12-24 06:56 , Processed in 0.111462 second(s), 18 queries .
