"Dualie" Lawnmower/ATV trailer
发表于 2021-8-31 23:56:12 | 显示全部楼层 |阅读模式
I sold the last lawnmower trailer that i built so I decided to build another one that was a little different from any that i have seen before. I built this one with dual wheels hoping to be able to haul more weight without having to worry about bending the axles. The frame is made from 1  1/2  square tubing  with a 2 inch ball coupler attached to the tongue. The floor of the trailer is 1/8 steel plate. The trailer 36 x48. The combined load rating for the tires is about 1300 pounds. I figure the trailer weighs about 200 pounds so I should be able to haul at least a 1000 pounds. Thanks for looking. Attached Images
Reply:I like it!
Reply:looks good! heavy duty too! i've gotta build myself a trailer like that for my lawn tractor, allways moving good sized rocks around the property. nice job!millermatic 200 millermatic 150miller bluestar 2Epurox / oxweld O/A
Reply:nice trailer
Reply:coolio............thas'a baby dualie        thermal arc 252i  -  millermatic 350P -   miller XMT, cp300ts, 30a 22a feeders, buttload of other millers, handfull of lincolns, couple of esabs  -   Hypertherm 1250 G3
GMT+8, 2025-12-24 06:57 , Processed in 0.105795 second(s), 18 queries .
