My new welder
发表于 2021-8-31 23:55:51 | 显示全部楼层 |阅读模式
Sorry for the long right up but im not even sure what im talken about never welded a thing!!Hey every1 after sometime of figureing out which weldr to get and the guidence from this forum i bought a lincoln sp135t mig. So i unpacked and began reading it says to use fluxcore i need a kit, but i looked that gun and it already has the parts that are in the kit. the tip is .035 and it has a gasless tip on. So im assuming all i need it flux core wire. When i look up wire for it it says nr-211-mp. I found some places to get it but whats the diff between nr211mp and e71t? they both say .035 flux core wire? can i use any .035 fluxcore wire? it came with a 10lb spool of mig wire so im guessing a 10lb of flux core would fit aswell. Thanks  any good sites to buy these things at? looken fora helm as well dont like my handheld face mask.
Reply:NR211MP is an E71-T.  In my opinion the NR211 is the best.  I tried just a couple of others.Yeah, run the fluxcore, but try it with gas too.  Fluxcore Electrode negativeMig, electrode Plus.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Home Depot carries what ya need, and a good price too.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:thanks every1 i just was able to get in touch with my friend as he is a pro welder for work. Hes giving me huge gas tank an told me to switch 2 mig. He said my welds look good nd are strong but they look dirty cuz of spatter. not sure what size tank but he said itsa bout 4.5 to 5 foot doig the amount of welding id be doing he said last me like a yr. also said to set the tank at 50psi. thanks
Reply:Originally Posted by ramz28thanks every1 i just was able to get in touch with my friend as he is a pro welder for work. Hes giving me huge gas tank an told me to switch 2 mig. He said my welds look good nd are strong but they look dirty cuz of spatter. not sure what size tank but he said itsa bout 4.5 to 5 foot doig the amount of welding id be doing he said last me like a yr. also said to set the tank at 50psi. thanks
Reply:Lincoln NR211 MP is a structurally rated wire. That number is a Lincoln number.Then there is an AWS number.And a ANSI number.The NR 211MP is a Multiple pass wire.If the wire ends in SP it is a single pass wire.AWS certified welding inspectorAWS certified welder
Reply:Lincoln NR211 MP is a structurally rated wire. That number is a Lincoln number.Then there is an AWS number.And a ASTM number.The NR 211MP is a Multiple pass wire.If the wire ends in SP it is a single pass wire.Nr211 is a flux core wire it has a hollow center with powdered flux in it.It does not need shielding gas.Filler wires that use powdered flux AND shielding gas are called duel shield wires.AWS certified welding inspectorAWS certified welder
Reply:A few ywars ago a store tried to sell me a 10# spool of NR211MP for $50.00 !!!I got mad and called LINCOLN and they said they sell it for $17.00.I went back to the store and told them they were overcharging and Lincoln was told by me about themThe salesman said it would sell it to me for $36.00 I accepted.Don't get ripped off by greedy businessmen.BTW i used 10 spools of that wire to build a 40 foot steel yacht. It was used for all the deck structures that were 10ga.AWS certified welding inspectorAWS certified welder
Reply:NR211   *sigh*    It hasn't got sharpes (sp?) so shouldn't be used on structual.  There has just been a big stink here on a few tank farms because of this.I'd rather be hunting........USE ENOUGH HEAT.......Drifting around Aussie welding more pipe up, for something different.....wanting to get home.
Reply:I don't really know much about this stuff, but I know how to find documents.  FWIW: Lincoln Electric offers a Certificate of Conformance for NR-211MP at this URL:http://www.mylincolnelectric.com/LEE...0_20080818.pdf-MondoMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
GMT+8, 2025-12-24 08:38 , Processed in 0.092888 second(s), 18 queries .
