Removeable drill press compound vice
发表于 2021-8-31 23:55:50 | 显示全部楼层 |阅读模式
I made this removable, but decided I needed an easier way to clamp things down.  Nice to have this.  It slides in the skids on the drill press table. Attached ImagesThe Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man"  Moses 1:39Link: My name is John, and I am a member of The Church of Jesus Christ of Latter-Day Saints.-- ColdCreekWorks.com --
Reply:A few more . . . . . .. Attached ImagesThe Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man"  Moses 1:39Link: My name is John, and I am a member of The Church of Jesus Christ of Latter-Day Saints.-- ColdCreekWorks.com --
Reply:Anybody else do something similar?  I like to compare to see if there are ways to simplify things.  For instance, I overcomplicated a mini press brake a while back, and will need to rebuild it.  Since then, I have seen some great, simplified designs that are probably much more effective.  Just curious.The Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man"  Moses 1:39Link: My name is John, and I am a member of The Church of Jesus Christ of Latter-Day Saints.-- ColdCreekWorks.com --
Reply:Looks good.I have that same model Delta Drill press in my woodworking shop.  I do not use the cross slide vise often on it so I just mounted the cross slide vise on a piece of plywood which I clamp the drill press table when I need it. The drill press in the garage is almost always used with a cross slide so I bolted that one directly to the t-slots in the drill press table.Larry "I feel for the man who cannot spell a word more than one way."  by Mark TwainLincoln AC225-SLincoln Weldpac 100 Miller Matic 180 (auto set)Miller Spectrum 375 ExtremeMiller Spoolmate 100Victor Super Range II
GMT+8, 2025-12-24 08:38 , Processed in 0.075987 second(s), 18 queries .
