Foundry tools
发表于 2021-8-31 23:55:48 | 显示全部楼层 |阅读模式
I recently went up to a B20 (bulge #20) crucible. Before I could start I needed a set of tongs for lifting the crucible from the furnace. I started by rendering the crucible so I could play with the hinge dimensions. This proved quick and easy. The lift arms are made from old 1/2" water pipe. The bottom pads are a simple shape slightly bent to hold the crucible. The rest is square tube. It's painted with manifold paint, which has held up surprisingly well.I also made a pouring shank. I didn't bother painting it. Enjoy. Attached Images
Reply:Tongs and shank both look pretty good. Are you pouring aluminum with that crucible?"SOUTHPAW" A wise person learns from another persons mistakes;A smart person learns from their own mistakes;But, a stupid person.............never learns.
Reply:Originally Posted by papabearTongs and shank both look pretty good. Are you pouring aluminum with that crucible?
Reply:For Hire,Good job..What program are you using for your designing and layout ..I am looking for a good program myself.. ThanksLeighLincoln Classic 300DLincoln SA 250Red d arc 300 dieselRanger 305Miller 302 Trailblazer12V Extreme SuitcaseMiller 200 DXVictor O/A torches3 dodge dually cummmins
Reply:Originally Posted by METALiculousFor Hire,Good job..What program are you using for your designing and layout ..I am looking for a good program myself.. Thanks
GMT+8, 2025-12-24 08:37 , Processed in 0.096355 second(s), 18 queries .
