1" cold roll and 1" shaft collar
发表于 2021-8-31 23:55:47 | 显示全部楼层 |阅读模式
i need some shaft collars for 1" cold roll. will 1" i.d. collars fit 1" cold roll? hopefully someone has tried this. gonna order the collars online ( ebay) , just wanna order once thanksdave
Reply:Originally Posted by RuffneckDavei need some shaft collars for 1" cold roll. will 1" i.d. collars fit 1" cold roll? hopefully someone has tried this. gonna order the collars online ( ebay) , just wanna order once thanksdave
Reply:thanks
Reply:found some today at the local motion industries, 1" will work if polished/ground a bit, 1 1/16" worked no prob.dave
Reply:Cold rolled doesn't have a close enough diameter tollerance to work all of the time with shaft collars.  You can buy ground shaft stock which does.  It will also work with bearings and whatever.
GMT+8, 2025-12-24 08:37 , Processed in 0.101981 second(s), 18 queries .
