20 inch line in oklahoma
发表于 2021-8-31 23:55:42 | 显示全部楼层 |阅读模式
this is the line we just did in watonga OK. NG line Attached ImagesAir vantage 500 on the 08' KWharris torchesl25 pro suitcasecomletely restored 1969 SA200 redfaceon my 08' duramaxPIMPN AINT EASY
Reply:what the hell is that?looks like  some kind of plastic with couplings..
Reply:Originally Posted by weldbeadwhat the hell is that?looks like  some kind of plastic with couplings..
Reply:Perfect Kodak moment.
Reply:ive seen yellow millwrapped pipe..i guess this is the same with some type of split coupling to protect the welded butts...
Reply:Its a pvc based paint.... after Xray they wrap the joints in some kinda wrap.. then its in the dirtAir vantage 500 on the 08' KWharris torchesl25 pro suitcasecomletely restored 1969 SA200 redfaceon my 08' duramaxPIMPN AINT EASY
Reply:thank you , sir
Reply:Bunch of different ways to make a living welding....Air vantage 500 on the 08' KWharris torchesl25 pro suitcasecomletely restored 1969 SA200 redfaceon my 08' duramaxPIMPN AINT EASY
Reply:If that is natural gas it seems a lot more work is going to be coming for this. Every news channel I listen to and every business channel has this something on NG.
Reply:Ya thats what im hearing too! moved from phoenix to oklahoma to get a peice of it.Air vantage 500 on the 08' KWharris torchesl25 pro suitcasecomletely restored 1969 SA200 redfaceon my 08' duramaxPIMPN AINT EASY
Reply:Originally Posted by weldbeadive seen yellow millwrapped pipe..i guess this is the same with some type of split coupling to protect the welded butts...
Reply:Originally Posted by KChoatethis is the line we just did in watonga OK. NG line
Reply:Just like the line they just ran by our neighborhood.  Wish I would've snapped a couple pics of the welding rigs they used . . . beastly looking monsters that looked like they weighed as much as a quarry truck.MikeConstans Fides et IntegritasLincoln Weldanpower 150 ACAirco Aircomatic MIGet CAV II w/ spoolgunMillermatic 30a wirefeeder
Reply:Say please punk! they dont have manners in canada? Attached ImagesAir vantage 500 on the 08' KWharris torchesl25 pro suitcasecomletely restored 1969 SA200 redfaceon my 08' duramaxPIMPN AINT EASY
Reply:sorry please its very nice.Have to work with alot of assholes,forget where my maners are sometimes.Thanks
Reply:bad ***Rod Burner
Reply:Now thats real welding there !!!  Hats off KChoate, I got 28 years in the pipeline welding, You got to love it.
Reply:The coating on that pipe is a 2 part fusion bonded epoxy, there is no PVC involved.The "couplings" as they were called are either bare uncoated welds or welds coated with a differentcolor of epoxy. If you see yellow those are heat activated shrink sleeves, not commonly used anymore.If you are going to post information for the world to read you should know a little about what you are talking about.Aeromax Service Truck w/ 6,000lb Crane to carry my toys.Miller Trailblazer 302'69 Lincoln SA-200A couple of Victor Jr's to make big pieces smaller..........
GMT+8, 2025-12-24 08:38 , Processed in 0.089119 second(s), 18 queries .
