Spare tire mount ideas?
发表于 2021-8-31 23:55:41 | 显示全部楼层 |阅读模式
dlturman posted a tire mount for his trailer and I don't want to hijack his thread, but that is something I have been toying with doing on the trailer I made, I made the trailer from an old travel trailer, but because I retained the propane tank mount I can't mount the tire on the tongue, and it sits pretty low to the ground also, so any ideas where I could mount it and not be in the way?I have always put it under the ATV's but this last year the strap broke on the back roads, so I figure it needs to be mounted somehow.Any ideas?
Reply:The bed is full width, otherwise I would put it on the side in front of a fender. Since that does not seem to fit, how about on the side of the tongue? Attached ImagesCity of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:I've seen them done under the tongue, but I don't think you have the height to make this work well. On equipment trailers it's common to mount them over the fenders. I've also seen guys add a bar underneath with a large nut welded to it. The tire mounts to the deck, and then the retainer screws down thru the deck into that nut to secure it. Last idea, add another front tire mount to the truck..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Looks like the front end is about the only place. I would fab something to let the tire sit a little higher if possible.UA Local 598
Reply:look at northern tool they have a lot Attached Images
Reply:Would be very easy to build something like that.UA Local 598
Reply:Your original location on the tongue would be fine.  You could also mount it on the front bar of the trailer on either side, too.  Me, I'd go for a pillar mount directly in front of one of the fenders so the wheel sits flush with the outside edge of the trailer.
Reply:We mount the propane tank on the tongue rack from when it was a trailer, but you know I could do around the fender, I do want one day to make removable sides, but I will have to see how it will all work out.thanks again for the help guys.
Reply:Remember to mount it on the right side of the trailer if you put it by the fender. This way your out of traffic when you have pulled off the road and you are trying to get the spare off the trailer.People are more violently opposed to fur than leather because it's safer to harass rich women than motorcycle gangs.  Unknown Pro Mig 175Hyphertherm 600Lots of toys at work
Reply:Do you put propane tanks in the holder? If you don't, I would get rid of it and put it there. If you do, I would make a post that comes up "between" the propane tanks and then mount the tire where the plywood is on the tongue. Attached Images
Reply:Between the wheels, under the deck, = no clearance problems. unbolted from the top deck, drops to ground. How often is access needed vs often is in the way, needing walk/work around.MIG, Stick, Oxy/Fuel, mostly one-off fabrication and repairsMC Road Racer'kit' Cobra2 Vista Cruisers'29 Ford AA Dualie dump   "Live-Free-Or Die"
Reply:I went to a junkyard and got the spare tire chain setup that matched my pickup and welded it to the bottom of the deck so the spare is tight underneath and doesnt sun rot.  I dont have to carry extra tools to get it out either.
Reply:Originally Posted by VC455Between the wheels, under the deck, = no clearance problems. unbolted from the top deck, drops to ground. How often is access needed vs often is in the way, needing walk/work around.
GMT+8, 2025-12-24 08:37 , Processed in 0.129200 second(s), 18 queries .
