Traded for Linoln 175 squarewave
发表于 2021-8-31 23:55:35 | 显示全部楼层 |阅读模式
I traded a used laptop for a Lincoln 175 squarewave.  Was this a good deal? Got the welder(its heavy for such a small package), two torches the LN9 that came with it from the factory, a Black diamond 17, foot control, stinger, a bag full of collets, gas lenses, etc. the machine is just over three years old from date on receipt.
Reply:I don't think the square wave will run the LN9, so send it to me right awayYou stole it!DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Thanks David. I couldn't afford to ship it all the way to New York so I will just keep it here and if you need it just drop by.
Reply:The little 175 is a pretty nice little Tig unit.  I have one that gets used regularly.  It doesn;t have all the bells and whistles, but it will get the job done nicely.  I don;t think he means an LN 9 (9 series) tig torch.  That was standard on the 175.  It didn't take long for me to go to the 17 series.I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:In two years, that welding equipment will be worth what it is now and the laptop will be worthless.
Reply:Hammack is there anything I need to watch out for or lil tricks you found about this machine? So far I have burnt a few rods with it, haven't tried the tig as I am out of Argon.
Reply:Are you old enough to handle the stigma?  "Square waves are only for Squares".How much good personal information such as credit card and PIN-umbers was still on the computer? Anything good for blackmail?? Your first draft of "How to Weld the Doors Of The IRS Shut For Good"??I better quit before I get either deleted or removed permanently. It's not even midnight, and there's no full moon....
Reply:Flatbustebroke; You made a good choice there. That is considering you can, or want to learn to weld?If you answered no to any of the questions, then I'll give you a used lap-top for the welder.Miller Thunderbolt 225Millermatic 130 XPLincoln HD 100 Forney C-5bt Arc welderPlasma Cutter Gianteach Cut40ACent Machinery Bandsaw Cent Machinery 16Speed Drill PressChicago Electric 130amp tig/90 ArcHobart 190 Mig spoolgun ready
Reply:Originally Posted by flatbustedbrokeHammack is there anything I need to watch out for or lil tricks you found about this machine? So far I have burnt a few rods with it, haven't tried the tig as I am out of Argon.
Reply:Originally Posted by STwelderFlatbustebroke; You made a good choice there. That is considering you can, or want to learn to weld?If you answered no to any of the questions, then I'll give you a used lap-top for the welder.
Reply:Originally Posted by Oldiron2Are you old enough to handle the stigma?  "Square waves are only for Squares".How much good personal information such as credit card and PIN-umbers was still on the computer? Anything good for blackmail?? Your first draft of "How to Weld the Doors Of The IRS Shut For Good"??I better quit before I get either deleted or removed permanently. It's not even midnight, and there's no full moon....
Reply:My first and current TIG welder is a Lincoln 175 Square Wave TIG.  I bought it from an industrial auction.  I have been messing around with it for a few months and it is really easy to use, I liken it to an easy to use oxy/fuel torch.I have only welded steel, haven't tried any aluminum yet.It is an exceptional stick welder as well, much smoother than the Lincoln buzz box it replaced.  Having a DC stick welder is very nice as well.Chris
GMT+8, 2025-12-24 08:37 , Processed in 0.102153 second(s), 18 queries .
