Aluminum DXF
发表于 2021-8-31 23:55:21 | 显示全部楼层 |阅读模式
Does anyone know where I can get an Aluminum shape library? I'm actually looking for 10" channel. DXF, DWG, or even PDF is fine.Common sense in an uncommon degree is what the world calls wisdom.
Reply:Not sure if this is what you need or not.. I am willing to help if you can be more specific.I can send dxf files too.Travis Attached Images10channel.pdf (2.8 KB, 43 views)
Reply:Yeah... Your PDF did not help. I am looking for the 10" x 3.5" aluminum channel profile. I have Mechanical 2012 with a library of shapes in steel, not aluminum. I'm trying to detail out some stairs that we are building.Common sense in an uncommon degree is what the world calls wisdom.
GMT+8, 2025-12-24 09:07 , Processed in 0.095470 second(s), 18 queries .
