Magswitch ideas
发表于 2021-8-31 23:55:20 | 显示全部楼层 |阅读模式
I would like to have a way to use my Magswitch without having to unbolt my ground clamp and bolt on the Magswitch. Any ideas?Lincoln Powermig 255Hypertherm Powermax 45Thermal Arc 161SOxweld 24R OA TorchStill Looking for an Old Round Top Idealarc 250
Reply:Bolt a piece of copper bar to the magswitch, then clamp to the bar.
Reply:Bolt a female dinse connector to the lug on the mag switch then set up a short whip you can add if neededSyncrowave 180 SDMillermatic 250XSnap On MW 120 Econopac 50Victor O/A with some Smith Attachments 30 X 50 shop with a 400 Amps
Reply:Here's what I ended up doing:I stripped an old lead, wrapped it, crimped a lug on it and attached it to the Magswitch.
Reply:Good idea I might be doing this to my mag switch soon best of both worlds aluminum with the regular clamp hard to get to grounds with the mag switch
GMT+8, 2025-12-24 09:06 , Processed in 0.093721 second(s), 18 queries .
