Odd bright flashing...
发表于 2021-8-31 23:55:20 | 显示全部楼层 |阅读模式
I have a small trailer that I have been working on @ home, there was a crack in the frame so b4 I patched it up I filled in the crack...because its so thin and its open I turned the welder down to 16g steel so it would not burn through, When I started doing this there would be a odd brighter then norm flash...it was not all the time...but it was so bright that I had to turn my glass darker...any reason why this would happen when it was turned down to 16g?Miller 211 & Spoolmate 100Miller Diversion 165Miller Spectrum 875
Reply:could be contaminants on the back side. could be salt build up maybe from looking at your location. more info and pics would help.225NT bobcatAEAD200LEScott 125mm175, mm252 w 30A, PT225mm211, TA 181iHyper Therm 380, cut master 529100X & XX, Digital Elite6 Victor setssmith little torch, meco midget kalamazoo band sawsteel max saw evoulution circular saw
Reply:I do not have any photos. I am welding on a broken frame that is very thin, I am using a MM211 with .30 wire, turned down to 16 gage, I am on 220v, I keep burning though, So I am doing a little @ a time to keep the temp down, but when using the MM211 on 16g I keep getting really bright flash's way brighter then when I am welding any thing thicker..just really odd...Miller 211 & Spoolmate 100Miller Diversion 165Miller Spectrum 875
Reply:are using an auto dimming shield? if so, it sounds like it might be the sheild
Reply:I agree it sounds like the shield. I've had it happen TIG welding with a Thermal Arc auto darkening. It has four sensors and one was loose and had fallen into the frame and seems to work fine for MIG but not for TIG. Ive also seen it with cheaper helmets like HF helmets.Sent from my Kindle Fire using TapatalkMiller Maxstar 200 DX - Syncrowave 200 - MillerMatic 200 - Bobcat 225 NT - Spoolmate 3035/SGA 1003 X Lincoln Power MIGs (200, 215XT 255)3 X Lincoln SP's (100, 125, 130)Thermal Arc 181i (spool gun and TIG torch)HT Powermax 1000 G3
Reply:I get that when I MIG stainless sheet.  I think it's contamination because it's intermittent.  If I clean it quite well & acetone scrub the stainless, I don't get the flashes.Clean it very well, front & back, heat it with a torch to burn out any road oil.  Should take care of the problem.MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
GMT+8, 2025-12-24 09:04 , Processed in 0.080659 second(s), 18 queries .
