Project Question/Suggestions-Table and Pics
发表于 2021-8-31 23:55:18 | 显示全部楼层 |阅读模式
I took a little of what I liked from several welding table designs.  I have some square tubing welding under the table. I have made a mount for my vise and 3-axis that is  mounted to square tubing that can slide into the tubing mounted to the table, so I can mount up the vise or 3-axis, as needed.  What I want to improve is the "play" that exists between the two pieces of square tubing.  Standing and facing the mounts and twisting to the left and right there is a noticeable movement.  When trying to cut tubing with a Sawzall, the vise needs to be more rigid. So of the problem may be the fact that the hole for the retention pin is larger than the pin.  I wonder if re-drilling to get a tighter fit of that pin to the hole may solve this? I want to modify what I have.  I have seen the pic of the mount where a piece of like 4 inch channel iron was used. in a vertical mount on the edge of the table.  But, my mount still would have the connection underneath the table and the movement would still need to be solved.  I thought about a smaller pin,  or a decreased hole( in both pieces of square tubing) to pin tolerance...? Wanted to sample the thoughts and experiences of others.Pics:  Thanks for the time and help.
Reply:Nice table.You could drill a 5/8" hole on 2 adjacent sides and weld a 1/2" nut to the outside of the receiver tube then use  1/2" bolts to hold tension on the tool like a couple of set screws. Weld a small piece of round stock to the bolt heads so you can tighten them by hand.Here's that set up on a roller stand I built for fabbing spiral stairs on. It easily holds 400-500 lb stairs with out slipping. For what you want I'd put the bolts on adjacent sides, instead of the same side, so they're 90* apart.Brian LeonardAppalachian Ironworks L.L.C.434 Long Branch Rd, Marshall, NC 28753828 649 9966828 702 [email protected]
Reply:Thanks Brian.  I was just stuck and trying to over-think it, I guess.  I appreciate the pics and help.  I have something similar for extending my table.  I just did not think of it.  I will post a pic.  But, your idea and pics are perfect.Thank you and have a good evening.
GMT+8, 2025-12-24 09:05 , Processed in 0.161333 second(s), 18 queries .
