Ooooooo......Pipe!
发表于 2021-8-31 23:55:17 | 显示全部楼层 |阅读模式
There's a demolition project going at the Conoco refinery in Ponca City, OK.I'm in need of some pipe for an upcoming fencing project (OH NO, NOT AGAIN).  Never fear, this is Fence Fairy Free fencing.  No more hiring idiots to build fenceI got lucky and got in on the last batch of used pipe sold.Made the first trip to pick up the 4" pipe in the pickup, saw the other goodies still left, and hotfooted it back up there this morning with the one ton and trailer128' of 4" sch40, already cut into 8' joints (some dude didn't show up for them after he asked for them to be cut)340' of 3" sch40 in 34' lengths150' of 2" sch40 (approximately) in various lengths, all multiples of 8ALL PRICED AT 20 CENTS A POUNDThis is some of the cleanest, and straightest, pipe I've seen in yearsEdit:  Worth 2 round trips at 180 miles each.  Tired butt, lottsa pipe Attached ImagesLast edited by farmersamm; 04-08-2010 at 08:46 PM."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Nice score!! "Recycling" at it's finest!Just another clown trying to be cool
Reply:Awesome 'haul'!  So what's the plan?  4" is for the posts and 3" for laterals?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:4's and 3's for corners, and 2's for top laterals.  I have a ton of 2" left over from last Summer's fiasco too"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Nothing better than a pile of used pipe around. Not bad for a day on the road
Reply:Like thisThe H is a weak design, always has been.  Triple H is a waste of money.All the stress is trying to topple the post, and a nice kicker solves the problem.That being said...............Any idiot can pull a corner assembly out of the ground if he/she overstretches the wire, a favorite of many the idiot Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:sorry, meant DOUBLE H"Any day above ground is a good day"http://www.farmersamm.com/
Reply:How well H-brackets work kinda depends on what part of the world you're in. They are used everywhere around here on top of the caprock. Cement them in this caliche rock and they are there short of a big winch truck or a cat. If all you have is dirt to set them in then it's a different deal and you need the angle braces.
Reply:Originally Posted by OldtimerHow well H-brackets work kinda depends on what part of the world you're in. They are used everywhere around here on top of the caprock. Cement them in this caliche rock and they are there short of a big winch truck or a cat. If all you have is dirt to set them in then it's a different deal and you need the angle braces.
Reply:Looks as if you got a good deal Samm, looks like sch. 120?. That fence will outlast all of us put together.....Mike
Reply:Score!  That oughta do a few corners...Work HARDER, not smarter! ------------------------ Miller Bobcat 250Millermatic 251Lincoln Precision TIG 185Hypertherm PM 600Hobart 135 HandlerOxweld 400 FlameMaster
Reply:I'm assuming that's your round bale hauling trailer.  Nice secondary use of that.Miller 250x & Lincoln V205-TSmith Oxy-Prop torch
Reply:What a score! Best I done was a couple hundred feet of 1 1/2" and 1"  316 SS tubing from a bakery being scrapped out.HobbyistSS/Aluminum cartATD 130 MIGEverlast 225 TIGSteel cartEverlast PP50 plasma cutterHarbor Freight 130 TIG/90 ArcHarbor Freight 100 Flux coreOxy/Acet
GMT+8, 2025-12-24 09:07 , Processed in 0.071017 second(s), 18 queries .
