lil help from the California boys
发表于 2021-8-31 23:55:00 | 显示全部楼层 |阅读模式
hey i wanna do some boat projects soon and would like to get some full 8x20 sheets of 5086  .125 and out here in az nobody can get it (least not sizes i want)ive been searching  thinking someone on the coast has to carry marine grade but so far the only source ive found is in louisiana biggest ive fond in calli is 4x10 would appreciate any help places to check thanks 350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:So, hook up the trailer and head east to La. instead of west to L.A. Just be sure to get enough to make the trip worth while, get some extra, cause you know once your buddies see some of the boats they will want you to make them one too.
Reply:Call industrial metal supply in Phx. They have alot of inventory including California locations.
Reply:might call this place  http://www.gatortraxboats.com/http://fandfboats.com/ wasnt there a guy on here that was building custom air boats? bet he could put you on some..tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:Many aluminum boats are built in Washington state.Pacific northwest areas.AWS certified welding inspectorAWS certified welder
GMT+8, 2025-12-24 08:55 , Processed in 0.096803 second(s), 18 queries .
