Mig vertical up manipulations
发表于 2021-8-31 23:54:55 | 显示全部楼层 |阅读模式
What mig vertical up manipulations  do you guys use? I have heard everything from a christmas tree weave to a inverted u. What else works, and what works and looks the best?
Reply:I weave it just like 7018.  Sometimes back and forth, for a fillet root pass I use the christmas tree way.I use a U if I have a big gap.David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:You will adapt to what works for you.I personally use the X-mas tree most of the time Sometimes I use other secret tricks   weld it like you own it
Reply:I use side to side with a steady progression up. Pause on the sides, fast across the middle.Here is a short video at http://www.weldingdata.com/pictures/1stpass3.wmv or as a .mov file at http://www.weldingdata.com/pictures/P1010002.MOVHave a nice dayhttp://www.weldingdata.com/
GMT+8, 2025-12-24 08:57 , Processed in 0.090257 second(s), 18 queries .
