floor panels, floor panels, floor panels?
发表于 2021-8-31 23:54:55 | 显示全部楼层 |阅读模式
what gauge are "reproduction floor pans" ?what gauge sheet metal was used as floor panels  (on a '67 Ford)?Will 120v mig with the flux core that came in the box handle it ?My research says it is a close call, but then I am not sure of the actual thickness or what all will  be involved in this job. Any helpful advice? All I know about it is "reproduction floor pans" on 1967 mustang.Thanks.
Reply:Get out the trusty mic, and compare to the chart.  You'll then know what you've got.If it's pretty thin, gas shielded wire would be best. Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Here's another chart for thicker stuff.BTW,   "Twenty Gauge"  from J.W. Harris Co. .030  75/25 works good Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Most floor pans are made from 18 - 16 gauge metal. The old cars had better metal in them compared to the newer cars. As farmeramm said, you really should use mig wire and C25 gas to get a decent job. Fluxcore will do the job but it is a lot harder and not near the job. Plus their is some info that links flux to premature rusting.Hope this helps. I have done several floor pans and body mods, so PM me anytime if you have a question.Have funMiller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
GMT+8, 2025-12-24 08:55 , Processed in 0.102573 second(s), 18 queries .
