A question on repairing spark plug threads
发表于 2021-8-31 23:54:52 | 显示全部楼层 |阅读模式
I would like to repair  the spark plug threads on my  Poulon chain saw. The metal looks like aluminum but aluminum rod will not stick.  I tried  JB Weld,  and another type of liquid metal, and these both did not work. i cannot find a heli -coil that will accept spark plug threads....perhaps I have not find the correct one?But welding the hole smaller then drilling and using the spark plug tap / thread chaser i have I think would be better...but i have not found a rod that will stick..what shall i use or what  other methods have you found to work well?Flywelder10-26-08
Reply:There are special Heli-coil inserts and taps for spark plugs.
Reply:Try NAPA or another parts store.  They have thread kits.David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Chainsaws, or at least any I've repaired, are magnesium.You'd be better off going the helicoil route as they are available and there'd be less chance of doing damage to the head, aka warpage.If you deo decide to weld it, watch your ground, make sure the area is clean. Magnesium is very prone to arcing if you don't have a good connection to ground, ask me how I know.....Mike
Reply:Great ideas guys! thanks to all!mrmikey,  would you share  how you know about the arcing tendency?
Reply:They also sell spark plug hole thread chasers.Try JP cycles.comAWS certified welding inspectorAWS certified welder
Reply:I have used Time-Sert to replace spark plug threads.  It is very common to lose threads in aluminum when steel threads are used on either a fastener or a spark plug!http://www.timesert.com/Powcon 200SMPowcon 300STVictor Journeyman O/A & CartApex Disc SanderCraftsman Belt/Disc Combo SanderWayne Air Compressor3 Craftsman Drill PressesEmerson Horizontal BandsawPorter-Cable Porta-Band7 Angle Grinders4 Bench Grinders
Reply:mrmikey, would you share how you know about the arcing tendency?
Reply:I agree with Fabtech. Dont use a helicoil. Use the Timesert insert,it is a sold steel piece not a coil. A helicoil can unscrew especially as short as plug threads are.mm135HTP Invertig 201 With water cooler9" Southbend LatheLots of hand tools.
Reply:Thanks for the new information guys! I have called around in my small town  for the Time inserts , no one has heard of them,  and they all offer heli-coils to me, along with :  " that's what all the machine shops use to replace spark plug threads, ..i ant never heard of then backing out, you do know you use red thread lock with the heli - coils?....you don't need anything else son, i got what you need, you just come on down, we'll fix you up"So  now my question is,  I need some suggestions on finding time inserts.thanks for sharing the info mrmikey, that was good knowledge to pass along, thanks.
Reply:napa: carries a similar product
Reply:Check out this web site:http://www.pendergrasstool.com/kits/spark_plug.htmNo matter what repair method you choose you shouyld have the cylinder head off so it can be handled carefully, cleaned, and the inside of the cylinder and intake kept clean.  This requires a gasket kit already.  So I am compelled to ask this next Dumb Question: what is the price of a replacement cylinder head for this chainsaw compared to the price of a Timesert (or other thread repair kit) plus your time mucking with this?-MondoMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:Originally Posted by Flywelder ...I have called around in my small town  for the Time inserts , no one has heard of them...
Reply:There are some short reach 18mm plugs from aviation motors, but not the kind of stuff you will find at an auto parts store.If it is one of the green poulans like a wild thing or wood shark then the jug is a very high sil casting well over 12%. They run a bare aluminium bore and chrome plated piston, so not easy to weld.Option you can bore and tap it out to 18mm and then use a screw in spark plug adapter, but the edge of the spark plug hole is very close to the squish band transition in the head so I am very doubtfull you could use an 18mm plug or 18mm plug adapter.Also the reach on these plugs is very short so you only get 4 or 5 threads engauging at best, does not give much purchase for an insert or Heli coil.I have mannaged to weld chainsaw jugs with success, but I suspect they are a different alloy than what you are working on. 4047 is closest common filler for these high sil castings, but 4043 not bad, 5356 is not what you want as it is not going to take the temperature.Lincoln PT185 TIGLincoln 175 MIGLincoln 240 amp AC StickLind Needle Arc plasma welderPlasma cutter, soon???
GMT+8, 2025-12-24 08:55 , Processed in 0.094243 second(s), 18 queries .
