Sintered Iron
发表于 2021-8-31 23:54:46 | 显示全部楼层 |阅读模式
I need to bore out a piece of sintered iron and bush it back to a smaller id...( 3/4" down to 5/8" ) and am thinking of tacking the bushing along with a light press fit...anyone know if welding sintered iron is possible?Walt
Reply:A spot of braze would probably be best.Good Luck
Reply:Never thought about brazeThanksWalt
Reply:You could drill and tap 3 evenly spaced holes around the bushing and install small set screws to lock it in place.Also consider using a retaining compound like Loctite 609.
GMT+8, 2025-12-24 10:20 , Processed in 0.095879 second(s), 18 queries .
